Esecuzione del bilanciamento del carico MT6000
Ho provato di nuovo a vedere la funzione di bilanciamento del carico, ma con o senza vpn politico le connessioni non vengono aggiunte.
in precedenza funzionava con vecchi firmware
test done with firmware 4.7.4
May I know which link is not added to load balance?
Or is there an exception in link failover?
Please share detail information more, thank you.
Wan1 + wan2
Please confirm whether Ethernet 1 (WAN1) and Ethernet 2 (WAN2) are available normally (green light)?
If it is available normally, configure the ratio of Load Balance, like Ethernet 1: Ethernet 2 is 1:1.
In this way, the router's LAN traffic will go on average by WAN 1 and WAN 2.
How to reproduce the issue mentioned here in v4.7.4? What previous firmware version worked fine?
I think it worked with 4.6 then I put the mt6000 back upstream of a load balance edge router that I would like to eliminate and leave only the mt6000
yes both wan online color green
Downgrade going from firmware 4.7.4 to 4.7 or 4.6 the router loses all settings?
"keep settings" is turn off by default for downgrade.
If you are not turn on manually, the settings will be lost.
As normal expectations, as long as both WANs are online and green, they should both be able to be balanced as links.
For simply, you can check what the Internet exit IP is through the web page on the connected client (like PC), such as ipinfo.io, ip.sb, etc.
For details, you can check the package through the router plug-in tcpdump.
where is "keep settings" activated?
When you install the firmware on the GL GUI -> SYSTEM -> Upgrade:
