Esim Management: Installing esim profile on inactive SIM card
I am using the Puli AX XE3000 with esims profiles. For the installation of a new profile an internet connection is needed. This connection can be established with the seed profile of the Eiotclub card - that's nice.
However, it is not possible to install the new profile on the other, inactive SIM card. The XE3000 has two slots and sometimes I would like to use the internet connection from slot 1 and install the new profile on esim card in slot 2.
As workaround I have to use the seed profile, which means that I can not use other esim cards than the Eiotclub card, or I have to put the active card to a mobile phone, activate tethering connect the router to the mobile phone to get Internet access, install the esim profile on the card in slot 2 and put everything back - including at least two reboots of the router for changing SIM cards.
Tedious process, that I'd like to avoid :slight_smile:
Is that possible with future updates?
Thanks
Ralf
