eSIM physical card or chip?
GL.iNet offers both eSIM chip cards and physical eSIM cards, featuring identical product configurations and usage methods. So my question is how do you tell if you have an eSIM chip or if you have to use an eSIM physical card? Using a Spitz x3000!!
For all our consumer-grade cellular products, including the X3000, there is no built-in eSIM chip.
To use eSIM functionality, you will need to purchase a separate physical eSIM card.
We recommend using eSIM cards from GL.iNet / partners, as these have been verified for compatibility:
Thanks
