Device: GL-MT3000
Firmware: 4.7.0 release 3
Disclamer: I'm not advanced network engineer... I try to setup vpn manually and suprized, that /etc/init.d/firewall restart returns 1. Try to solve it. If it's not a problem, close the topic.
Problem: /etc/init.d/firewall restart returns 1.
Reason:
config include 'portal_ttl'
option path '/etc/firewall-portal.user'
option reload '1'
script '/etc/firewall-portal.user' returns 1.
/etc/firewall-portal.user:
iptables -t mangle -N PORTAL_TTL 2>/dev/null
iptables -t mangle -F PORTAL_TTL
iptables -t mangle -D POSTROUTING -o apclix0 -j PORTAL_TTL 2>/dev/null
ip6tables -t mangle -N PORTAL_TTL 2>/dev/null
ip6tables -t mangle -F PORTAL_TTL
ip6tables -t mangle -D POSTROUTING -o apclix0 -j PORTAL_TTL 2>/dev/null
better:
if iptables -t mangle -C POSTROUTING -o apclix0 -j PORTAL_TTL 2>/dev/null; then
fi
if ip6tables -t mangle -C POSTROUTING -o apclix0 -j PORTAL_TTL 2>/dev/null; then
fi
Now it returns 0.
