I setup my Opal router with ethernet only and am having problems. I can access the admin panel via 192.168.8.1 so long as there is no ethernet cable plugged into the WAN port of my opal router. However then I can't browse the internet. As soon as I have my home network's ethernet cable plugged into the Opal router's WAN port ( and another ethernet cable plugged into the Opal router's LAN port and going into my laptop) I lose connectivity to the Opal router admin panel, and if my VPN is enabled, I can't access the internet either.
I grabbed the log of one such instance of this problem:
Sat Aug 3 21:08:01 2024 daemon.notice netifd: sf_eth_event port 1 updown 0 is_wan 0 vlanid 1 ifname eth0
Sat Aug 3 21:08:13 2024 daemon.info dnsmasq-dhcp[1834]: DHCPDISCOVER(br-lan) 192.168.1.232 a0:29:19:22:93:42
Sat Aug 3 21:08:13 2024 daemon.info dnsmasq-dhcp[1834]: DHCPOFFER(br-lan) 192.168.8.189 a0:29:19:22:93:42
Sat Aug 3 21:08:13 2024 daemon.info dnsmasq-dhcp[1834]: DHCPREQUEST(br-lan) 192.168.8.189 a0:29:19:22:93:42
Sat Aug 3 21:08:13 2024 daemon.info dnsmasq-dhcp[1834]: DHCPACK(br-lan) 192.168.8.189 a0:29:19:22:93:42 ndb-Latitude-5420
Sat Aug 3 21:08:13 2024 daemon.notice netifd: sf_eth_event port 1 updown 1 is_wan 0 vlanid 1 ifname eth0
Sat Aug 3 21:08:13 2024 user.notice dhcplease: this mac:7c:c2:c6:45:05:72 is not in wldevlist or devlist
Sat Aug 3 21:08:14 2024 user.notice dhcplease: this mac:a0:29:19:22:93:42 is not in wldevlist or devlist
Sat Aug 3 21:08:30 2024 daemon.notice netifd: sf_eth_event port 0 updown 1 is_wan 1 vlanid 2 ifname eth0
Sat Aug 3 21:08:30 2024 daemon.notice netifd: VLAN 'eth0.2' link is up
Sat Aug 3 21:08:30 2024 daemon.notice netifd: Interface 'wan' has link connectivity
Sat Aug 3 21:08:30 2024 daemon.notice netifd: Interface 'wan' is setting up now
Sat Aug 3 21:08:30 2024 daemon.notice netifd: +++++++++++++++++++++set link state 1 dev eth0.2
Sat Aug 3 21:08:30 2024 daemon.notice netifd: wan (28052): udhcpc: started, v1.29.3
Sat Aug 3 21:08:30 2024 daemon.notice netifd: wan (28052): udhcpc: sending discover
Sat Aug 3 21:08:31 2024 daemon.notice netifd: wan (28052): udhcpc: sending select for 192.168.1.158
Sat Aug 3 21:08:32 2024 daemon.notice netifd: wan (28052): udhcpc: lease of 192.168.1.158 obtained, lease time 86400
Sat Aug 3 21:08:32 2024 daemon.warn dnsmasq[1834]: no servers found in /tmp/resolv.conf.auto, will retry
Sat Aug 3 21:08:32 2024 daemon.notice netifd: Interface 'wan' is now up
Sat Aug 3 21:08:32 2024 kern.warn kernel: [ 3967.034109] [hnat info]add wan ip c0a8019e pf 24 index 0 vld 1 name eth0.2
Sat Aug 3 21:08:32 2024 daemon.info dnsmasq[1834]: reading /tmp/resolv.conf.auto
Sat Aug 3 21:08:32 2024 daemon.info dnsmasq[1834]: using local addresses only for domain test
Sat Aug 3 21:08:32 2024 daemon.info dnsmasq[1834]: using local addresses only for domain onion
Sat Aug 3 21:08:32 2024 daemon.notice netifd: wan (28052): /lib/netifd/dhcp.script: line 62: netclash: not found
Sat Aug 3 21:08:32 2024 daemon.info dnsmasq[1834]: using local addresses only for domain localhost
Sat Aug 3 21:08:32 2024 daemon.info dnsmasq[1834]: using local addresses only for domain invalid
Sat Aug 3 21:08:32 2024 daemon.info dnsmasq[1834]: using local addresses only for domain bind
Sat Aug 3 21:08:32 2024 daemon.info dnsmasq[1834]: using local addresses only for domain lan
Sat Aug 3 21:08:32 2024 daemon.info dnsmasq[1834]: using nameserver 192.168.1.1#53
Sat Aug 3 21:08:33 2024 user.notice mwan3[28076]: Execute ifup event on interface wan (eth0.2)
Sat Aug 3 21:08:34 2024 user.notice mwan3[28076]: Starting tracker on interface wan (eth0.2)
Sat Aug 3 21:08:34 2024 user.notice mwan3track[16865]: Stopping mwan3track for interface "wan"
Sat Aug 3 21:08:38 2024 user.notice firewall: Reloading firewall due to ifup of wan (eth0.2)
Sat Aug 3 21:08:38 2024 user.notice relay: Reloading relay due to connected of wan (eth0.2)
Sat Aug 3 21:08:39 2024 user.notice relay: Reloading relay due to ifup of wan (eth0.2)
Sat Aug 3 21:09:19 2024 daemon.info dnscrypt-proxy[1929]: dnscrypt-proxy Refetching server certificates
Sat Aug 3 21:09:26 2024 daemon.notice netifd: sf_eth_event port 0 updown 0 is_wan 1 vlanid 2 ifname eth0
Sat Aug 3 21:09:26 2024 daemon.notice netifd: VLAN 'eth0.2' link is down
Sat Aug 3 21:09:26 2024 daemon.notice netifd: Interface 'wan' has link connectivity loss
Sat Aug 3 21:09:26 2024 kern.warn kernel: [ 4021.574183] [hnat info]del wan ip c0a8019e pf 24 index 0
Sat Aug 3 21:09:26 2024 daemon.notice netifd: +++++++++++++++++++++set link state 0 dev eth0.2
Sat Aug 3 21:09:26 2024 daemon.notice netifd: wan (28052): udhcpc: received SIGTERM
Sat Aug 3 21:09:27 2024 user.notice mwan3[30590]: Execute ifdown event on interface wan (unknown)
Sat Aug 3 21:09:27 2024 user.info mwan3track[28469]: Detect ifdown event on interface wan (eth0.2)
Sat Aug 3 21:09:27 2024 user.notice mwan3track[28469]: Interface wan (eth0.2) is offline
Sat Aug 3 21:09:29 2024 user.notice firewall: Reloading firewall due to ifdown of wan ()
Sat Aug 3 21:09:29 2024 user.notice relay: Reloading relay due to disconnected of wan (eth0.2)
Sat Aug 3 21:09:30 2024 user.notice relay: Reloading relay due to ifdown of wan ()
Sat Aug 3 21:09:34 2024 daemon.err dnscrypt-proxy[1929]: dnscrypt-proxy Unable to retrieve server certificates
Sat Aug 3 21:09:34 2024 daemon.notice netifd: sf_eth_event port 1 updown 0 is_wan 0 vlanid 1 ifname eth0
Sat Aug 3 21:09:37 2024 daemon.notice netifd: sf_eth_event port 1 updown 1 is_wan 0 vlanid 1 ifname eth0
Sat Aug 3 21:09:41 2024 daemon.notice netifd: sf_eth_event port 1 updown 0 is_wan 0 vlanid 1 ifname eth0
Sat Aug 3 21:09:53 2024 daemon.info dnsmasq-dhcp[1834]: DHCPREQUEST(br-lan) 192.168.8.189 a0:29:19:22:93:42
Sat Aug 3 21:09:53 2024 daemon.info dnsmasq-dhcp[1834]: DHCPACK(br-lan) 192.168.8.189 a0:29:19:22:93:42 ndb-Latitude-5420
Sat Aug 3 21:09:53 2024 user.notice dhcplease: this mac:a0:29:19:22:93:42 is not in wldevlist or devlist
Sat Aug 3 21:09:53 2024 daemon.notice netifd: sf_eth_event port 1 updown 1 is_wan 0 vlanid 1 ifname eth0
