Hello I have a GL-MT6000 running firmware 4.5.8.
I recently acquired the Flint 2 router and would like to have it output the wireless network along with having usage of the ethernet ports for LAN access. I have a pfsense box upstream that handles all routing.
Things I have tried:
In Access Point mode the ethernet ports will not allow connectivity to the LAN.
In Drop-In Gateway mode the flint 2 router still wants to handle routing features, if I disable DHCP in this mode it will not pass on the DHCP routing from the pfsense box.
I previously had a router running DD-WRT in gateway mode which simply created a wireless network and acted like a switch allowing ethernet port usage on the box.
Thank you for any guidance. Perhaps I am missing something simply, I am open to any command line/shell or alternative firmware recommendations.
