Been using my Slate plus during my last holiday (firmware 4.2.3), unfortunately this was not a good experience. I have used a GL iNet AR150 for years and I wanted an upgrade. Mainly because a repeater halves your bandwidth when using the same band (2.4GHz). So when using 2.4GHz for the WAN and 5GHz for the client devices, the bandwidth wont suffer, that was my idea.
Unfortunately the speeds were terrible, when connected directly to the hotel wifi (2.4GHz) I got 50Mbit, but when connecting through the Slate I got 5Mbit. Long story short, I was also using a USB3 flashdrive, this is causing interference with 2.4GHz. I discovered this issue after I got back, so I couldn’t test it at the holiday location, but I ran some tests at home and speeds are now as you would expect.
For testing I installed https://openspeedtest.com on my NAS at home.
I also installed Ookly speedtest on the router, so I could test the speed between router and WAN ( didnt use it though)
See Speedtest CLI: Internet speed test for the command line, you can do a wget https://install.speedtest.net/app/cli/ookla-speedtest-1.2.0-linux-armel.tgz
Here are my results
| GL iNet AR150 | GL iNet A1300 (slate+) | Netgear WAX202 | |||||
| WAN | LAN | Download | Upload | Download | Upload | Download | Upload |
| Cable | Cable | 68,60 | 77,48 | 937,60 | 977,07 | 917,33 | 980,43 |
| Cable | 2.4 GHz | 38,94 | 28,95 | 78,98 | 75,87 | 123,63 | 118,97 |
| Cable | 5 GHz | x | x | 388,30 | 431,00 | 394,61 | 388,20 |
| 2.4 GHz | Cable | 7,53 | 29,53 | 109,13 | 100,68 | ||
| 5 GHz | Cable | x | x | 518,28 | 451,85 | ||
| 2.4 GHz | 2.4 GHz | 9,60 | 16,90 | 46,13 | 42,85 | ||
| 2.4 GHz | 5 GHz | x | x | 106,23 | 99,43 | ||
| 5 GHz | 2.4 GHz | x | x | 91,34 | 91,87 | ||
| 5 GHz | 5 GHz | x | x | 189,25 | 202,08 |
So comparing 2.4Ghz using only home router I get 123 Mbit / 110 Mbit (down/up)
When using 5GHz for WAN and 2.4GHz internally I get 106 Mbit / 99 Mbit which is almost identical.
When using 2.4GHz for both WAN and internally you do indeed see the speed being cut in half.
Other conclusions, use 5GHz for both, this has the best speeds when using as a repeater.
I hope this post can help someone at some point.
