Can anyone tell me what this means? Router temporaily showed no internet. Still had IP from WAN.
Mon Oct 14 11:23:04 2024 kern.err kernel: [43907.450344] 7986@C12L1,Peer_Vendor_Spec_Action() 817: Peer_Vendor_Spec_Action:frame len check error
Mon Oct 14 11:24:02 2024 kern.err kernel: [43965.458338] 7986@C12L1,Peer_Vendor_Spec_Action() 817: Peer_Vendor_Spec_Action:frame len check error
bruce
2
The log means that: The router Wi-Fi received a packet in an invalid format.
But it does not relate to the 'Router temporaily showed no internet'.
In fact, the device connected to the router, if available to access the Internet?
If yes, probably one or some IPs in Multi-WAN cannot ping-check (maybe due to your ISP).
If the router is not connected to multiple WANs, can disable this feature.
system
Closed
5
