I just checked into a hotel with 215 Mbps symmetrical speed which I measured while connected via ethernet to my GL iNet Beryl AX (w/o Tailscale enabled). I turn on my Tailscale exit node and I’m getting 7 Mbps down, 10 Mbps up. My exit node is a Raspberry Pi 4B with a short wired connection to my router at home. Via ssh, I run “speedtest-cli” on the Pi and the result is around 800 Mbps download and 23 Mbps upload.
I understand my maximum download speed at the client side is going to be ~23 Mbps, but I’m not getting anywhere near that. I also realize I have a relay connection right now with Derp servers which definitely will decrease speeds, but should it really be this drastic? I wish it was direct connection.
It would probably have the same issue and just use ZeroTier relay servers instead. I doubt speed would be better since Wireguard actually has less overhead than ZeroTier.
Ah, I see you've taken the ambitious route of expanding your empire to both here and Reddit. Who knew monopolizing platforms with your services could be so riveting? Bold move! Bravo!
Yep, I saw the need for it so I gave people what they want. Also tired of seeing misinformation online and people taking advantage selling marked up hardware. I digress...
