Expose wireguard servers endpoint on gl-sdk
I think it would be nice to have the endpoint field inside the profiles section visible and it's port.
As how the current behaviour is:
Normally under the expected situation the profile peer gets automatically the endpoint defined from wan which gets fetched from ip.sb I think, because it even shows my public ip on dual nat.
This will work in alot of situations.
But this fail to work when the router is a second router, whereas the first router portforwards, or when the upstream router routes a vpn, then the endpoint for wan shows the vpn ip.
I'm not requesting to change the automatic behaviour, but I think there needs head room to manually set the endpoint and port in the profile/peer and so on the QR code gets adjusted.
Currently I have Brume3 sitting as a backup vpn server I really want to have my configuration map to a specific port and endpoint.
This is also usefull if one already has a different ddns setup other than glddns on a upstream router which already routes on vpn too.
Thank you for your suggestion.
The feature to allow custom addresses when exporting VPN configuration profiles from the VPN server page is already on roadmap.
