What is this? I am trying to connect via WIFI at a coffee shop but I need the VPN working on the router.
SO, I did some research and found this statement:
Some customer grade routers have problems with IPSec but, more likely, a coffe shop simply allows ports 80 and 443 through the firewall and noting else. The default OpenVPN port is 1194 which may be blocked by a restrictive firewall . I strongly believe that Mullvad will allow you to use port 443 to connect to their servers.
WHen I went home, I tested the router and it works great. BUT, not at the coffee shop which is why I bought this router in the first place.
My question is, if the above is true, how do I got about change the port 1194 to 443 or 80?
Best option is get another GL router, plug it in to your current router at home and set it up with wireguard server, then you can just connect to it anywhere without any issues… Wireguard VPN Server would connect you to home and then use Express VPN from the current router. No more config issues
