I have 2 MV-1000. The main site has 192.168.0 and the node has 192.168.8. and they are connected correctly on a site to site connection.
I am trying to see if it is possible to have the following.
DHCP range on main DHCP range on node
192.168.0.2-100 192.168.0.102-200
gateway 192.168.0.1 192.168.0.101
So normal internet traffic on main will go through 0.1 and from node will go out through 0.101.
Is that possible? I know I can restrict the DHCP ranges on both sides but then, will it work seamlessly when I connect the site-to-site connection?
Thanks.
