Hello
Can memory be extended via SD? I am total dumbass in SSH, so is there any GUI? Can Technical Support for Routers support help me?
Hello
I did not quite understand your question, extend memory for what to do? for Network share?
If you mean exroot, then yes.
But not recommended for newbies.
For plugins. To add various plugins (like Tor, Samba (which should work with USB stick etc)
What is this? Any guidance? Does it require SSH? Or it have any GUI?
No GUI.
Requires SSH and good understanding of what you are doing.
https://openwrt.org/docs/guide-user/additional-software/extroot_configuration
Maybe this?
X750v2 Spitz not enough space for plugins? - #11 by Frankdobermann (I think it is identical on all routers)
Will you have processing enough to run all this?
Just set up as overlay in LuCi…
