I’ve got two VLANs setup, but only clients on “lan” are populated in the UI. So when I connect to the alternate SSID/VLAN, they do not show up in the UI. As a result, clients on the alternate VLAN are not available for QoS or port forwarding.
Is there a way to extend this functionality to a second interface other than “lan”? From what I can tell, it looks like the logic that pulls clients into the UI is within the API binary (which I can’t modify) but thought I would check anyway. Thanks!
