Ok new to all this Unix/Linux stuff. Trying to work out external storage nomenclature.
Hokay, played with a bit so original issue gone. Now understand what the situation is.
sda2 is a “leftover” drive from when I first put in an SD-Card with two partitions on it. I have reformatted the card into a single partition and as such should only have sda1 but sda2 is a leftover.
How do I remove this “device” sda 2 that doesn’t exist anymore?
Additionally is there any way I can put some “security” on the drive rather than just read/write access. Can I protect with a username/password ? Do I need to add additional packages to support SAMBA…?
All things done, there is require username and password for file sharing, but it doesn't work once router reboot. We have to change the file /etc/hotplug.d/block/50-samba line "uci delete samba.@sambashare[$i]" to "exit". The code as follow.
if [ ! -e "$sharepath" -o "$d" = "$label" ]
then
# uci delete samba.@sambashare[$i]
exit
fi
