I am using my mudi on the camping site and use the 4G modem as my main WAN. However I would like that in case a problem with 4G arises, the router switches over to the WiFi of the camping site. When 4G returns, it should switch back again. If I try the repeater option, the WiFi remains the 1 st choice and it seems there arises a conflict with the 4G connection
Thx for the feedback, tried that but it seems to connect to both WiFi and 4G at the same time causing a kind of instability and interference. I would prefer that it only tries to connect to the wifi when my 4G is failing.
Today, I was at the camping site and changed etc/config/network metric. To my surprise the value was changed back after a short while. How is this possible?
I did change both files. I really think that every time it re-connects to the WiFi, it does recreate the interface. Maybe somebody knows how to change this?
