Hi!
How to install Fail2Ban to protect LuCi from brute force in LAN (!). Network is open, I know it is not good. I don’t want to set password. No I don’t need guest network.
Please, help me to install fail2ban to luci : )
Hi!
Well, since you already know about your security flaws I can just link to the official (!) wiki about how to secure luci: https://openwrt.org/docs/guide-user/luci/luci.secure#securing_against_brute-force_attacks
There is no recommendation for fail2ban for luci - I am not even sure if it's possible.
@admon but it is nginx in Gl one
uHTTPd is the web server responsible of hosting the Luci web interface. By default uHTTPd listens to 0.0.0.0 which makes it accessible from the local network.
To prevent LuCI web interface from being brute-forced from attackers already in the local network, we are going to edit the uHTTPd config file and change its settings, so it only listens to localhost.
You can do the same with nginx.
The only "real" way to protect the interface is by making it not available to everyone.
I just need to add rate limit. In app of gl there is such feature…
Yeah, but luci is a 3rd party app. So you would need to talk to the luci developers about this one.
And since they wrote in the wiki that they think protecting luci by using an SSH tunnel is the best way ... I doubt they will add something like a rate-limit at all.
Is it possible on android? I don’t have PC as it is redundant for me
I don't know, depends on the SSH client possibilities.
Why separate interfaces? Why devs not just write plugin(s) and theme for default Luci to customise it?
Developers choose separate interfaces because that's how GL devices are designed. It's not something we can change, so there's no need to discuss it further.
Luci is some extra and for many people not needed anyway.
But I am using exactly it. Because firewall in GL gui castrated (no block options), no custom plugins gui (luci supports it), no custom path to hosts files (lush in DNSMASQ supports it) and much more…
Understandable. I use it by myself, sometimes.
But in that case, you must accept that there are some extra steps to go if you want to stay secure. Or you choose a password that long that there is no way to bruteforce it.
Edit:
You could even stop nginx and only spin it up when you need it. That would be pretty secure.
You mean for admin? Can I at least change root username? Do you have examples (not your own)? I see every single password can be easily brute forced as everyone knows that letters can be replaced by digits etc
