Hello Developer:
I can not compile the firmware when I use the source code of Gl-iNet Official.
And This is texts that were put out by the terminal.
make[3]: Entering directory '/home/runner/work/Actions-OpenWrt/Actions- OpenWrt/openwrt/feeds/gli_pub/luci-app-shadowsocks'
touch /home/runner/work/Actions-OpenWrt/Actions-OpenWrt/openwrt/build_dir/target-mips_24kc_musl/luci-app-shadowsocks/.prepared_ce689d8f048b4b55c19b728e15295fc2_6664517399ebbbc92a37c5bb081b5c53_check
po2lmo /home/runner/work/Actions-OpenWrt/Actions-OpenWrt/openwrt/feeds/gli_pub/luci-app-shadowsocks/files/luci/i18n/shadowsocks.zh-cn.po /home/runner/work/Actions-OpenWrt/Actions-OpenWrt/openwrt/build_dir/target-mips_24kc_musl/l
uci-app-shadowsocks/shadowsocks.zh-cn.lmo;
bash: po2lmo: command not found
Makefile:92: recipe for target '/home/runner/work/Actions-OpenWrt/Actions-OpenWrt/openwrt/build_dir/target-mips_24kc_musl/luci-app-shadowsocks/.prepared_ce689d8f048b4b55c19b728e15295fc2_6664517399ebbbc92a37c5bb081b5c53' failed
make[3]: *** [/home/runner/work/Actions-OpenWrt/Actions-OpenWrt/openwrt/build_dir/target-mips_24kc_musl/luci-app-shadowsocks/.prepared_ce689d8f048b4b55c19b728e15295fc2_6664517399ebbbc92a37c5bb081b5c53] Error 127
make[3]: Leaving directory '/home/runner/work/Actions-OpenWrt/Actions-OpenWrt/openwrt/feeds/gli_pub/luci-app-shadowsocks'
time: package/feeds/gli_pub/luci-app-shadowsocks/compile#0.11#0.02#0.14
package/Makefile:111: recipe for target 'package/feeds/gli_pub/luci-app-shadowsocks/compile' failed
make[2]: *** [package/feeds/gli_pub/luci-app-shadowsocks/compile] Error 2
make[2]: Leaving directory '/home/runner/work/Actions-OpenWrt/Actions-OpenWrt/openwrt'
package/Makefile:107: recipe for target '/home/runner/work/Actions-OpenWrt/Actions-OpenWrt/openwrt/staging_dir/target-mips_24kc_musl/stamp/.package_compile' failed
make[1]: *** [/home/runner/work/Actions-OpenWrt/Actions-OpenWrt/openwrt/staging_dir/target-mips_24kc_musl/stamp/.package_compile] Error 2
make[1]: Leaving directory '/home/runner/work/Actions-OpenWrt/Actions-OpenWrt/openwrt'
/home/runner/work/Actions-OpenWrt/Actions-OpenWrt/openwrt/include/toplevel.mk:225: recipe for target 'world' failed
make: *** [world] Error 2
runner@fv-az83:~/work/Actions-OpenWrt/Actions-OpenWrt/openwrt$ po2lmo
I checked it a little.Then I found an error on “shadowsocks”
Maybe,It can not found the right commands.
So,What I can do to solve this trouble?
- To add a little
I cut a piece of text from the terminal. It does not found the libraries “libmbedtls”
And There are several similar ones that I didn’t cut it.
Makefile 'package/feeds/gli_pub/shadowsocks-libev/Makefile' has a build dependency on 'libmbedtls', which does not exist
Chinese
你好,开发者
我使用官方Gl-iNet的原式码无法完成Openwrt固件的编译
我截获了终端机输出的文本(见上文).
发现编译"luci-app-shadowsocks(shadowsocks)"时出现错误.
大概是找不到对应的指令(bash: po2lmo: command not found)
所以,我该怎么解决它呢?
