Feature Request: ability to "Pin" keyboard shortcuts to top bar
I normally don’t keep the “toolbox” or “settings” option expanded; just keeping the top tool bar (settings/toolbox/accessories/virtual media/etc.) visible.
The ability to “pin” a keyboard shortcut or various items under “settings” to allow a quick access, would be really handy quite often.
potential user-selectable top bar toggles:
  • show virtual keyboard
  • bad link mode
  • Microphone/mute
  • quality - drop down (I prefer to adjust manually as needed vs the “smart” mode)
  • Wake on Lan
  • Shortcut (Pin various Shortcuts)
  • Paste (click in box/paste to remote device)
Thank you for your report.
I will forward it to the R&D team for evaluation.
