[feature request (and my workaround guide)] wireguard client as "exit node" or "Allow Remote Access the [WAN] Subnet"
I am building site-to-site with my Slate 7 and a third-party home router (Router2), and I want a route like:
third-party router LAN (192.168.10.x) → [Router2] – wireguard → [gl inet router] → gl inet router WAN (10.x.x.x)
It means I need the gl-inet router acts like an “exit node in Tailscale”, but Tailscale is not support by my Router2 so I can only use the basic wireguard. Also only the Router2 has a public ip, not the gl-inet router, so the gl-inet router can only use the wireguard client mode.
Unfortunately, although we have an “Allow Remote Access the LAN Subnet” option with can let we access gl-inet’s LAN from Router2’s LAN, but there are not an option like “Allow Remote Access the [WAN] Subnet” let me access gl-inet’s WAN from Router2’s LAN.
Luckily, after some study I make it works with a little hack (I have NO “IP Masquerading” for wireguard on both routers, the config may difference in other condition) :
  1. enable LUCI (Advanced Settings)
  2. allow wgclient1 → WAN:
    In luci → firewall → Zones → wgclient1, add “WAN” zone to “Allow forward to destination zones:”
  3. config wan → wgclient route:
    In luci → Routing → IPv4 Rules, add a routing: set Destination=192.168.10.0/24 (Router2’s LAN subset), Table=1001 (the table for wgclient1, find it with ip rule show, e.g. 6000: from all fwmark 0x1000/0xf000 lookup 1001)
  4. In VPN → WireGuard Client, add “192.168.10.0/24” to wgclient1 allowed_ips (this will create a route in table 1001, default’s 0.0.0.0/0 won’t work)
This solved my needs, I recorded it here and wish it can help someone else, and I also wish this can be added as an official feature.
Thanks for the detailed guide.
The VPN features in the GL UI are currently focused mainly on client/server (C/S) scenarios rather than site-to-site (S2S) or other architectures.
We’ll collect this request and pass it along to the product team for evaluation to see whether broader use cases can be better supported in the future.
