We curently have an option to choose between 2 services Cloudflare or NextDNS for DoT on the custom DNS section.
We would like to have the possibility to define a custom DoT name instead of having only those 2 choices, otherwise can someone point me to the configuration file where such setting is saved?
Unfortunately it seems the 2 DoT choices (Cloudflare/NextDNS) are hardcoded, so to get an other DoT service working, I had to override an one of the 2 servers configuration files:
/etc/stubby/stubby_nextdns.yml
/etc/stubby/stubby_nextdns_default.yml
Hopefully this changes will survive after updates.
I would also like to use a different DoT provider than the two providers hardcoded in. It would be good if we could specify a DNS over TLS provider instead of only having two to pick from.
(In my case I want to use Quad9 so if it was added to the hardcoded list I would be happy about that. But seems like it might be easier to just let us specify a provider?)
