Feature Request: Editable Tailscale Subnet Routes
When enabling Tailscale Subnet Routing for the Comet Pro (or other devices, for that matter), I'd love to be able to edit the subnets. For example, I have a VLAN for WiFi and another for hardline - but I'd rather advertise the entire /16 instead of two specific /24s. I think from a UI perspective this should be easy, you show the comma-separated subnets and making them clickable to edit them shouldn't be much of a complication.
Thanks for the feedback. Currently, you can set this via the terminal by running:
 tailscale set --advertise-routes <ip-range>
We’ve recorded your request for editable subnet routes in the Web UI and forwarded it to our product team for evaluation.
Thanks! Will that persist across firmware updates? That's always my concern with CLI commands.
When performing a local firmware upgrade with "Save current configuration" enabled, the current configuration will be preserved.
