Feature Request - GL-RM10 WiFi Bridge
It would be really helpful to be able to use the Ethernet port to bridge to the WiFi if the GL-RM10 is connected to WiFi.
One of my main uses for the KVM is updating or configuring small computers that are then later put in other environments, however many of these do not have WiFi. Being able to use the KVM’s WiFi to provide basic connectivity to the connected computer would be really useful.
We've received your request, and I'll forward it to the R&D team. Thank you for your valuable suggestion. I believe that purchasing a Gl.inet router paired with an RM10 to handle updated configurations for small computers would be a better option for you in dealing with complex network environments.
I can already do this with a small router, however it’s another device, another power supply, etc.
The beauty of the RM10 is with one device and no external power supply you can just plug it into anything and have full access.
If that access also allowed me to run updates (for example) on a device that is not wifi equipped via the RM10 it would be really helpful.
It's unlikely to support such a feature. The network configuration of this device is fixed.It’s NOT an router
