Is it possible to have a timer on the mouse jiggler? Some physical mouse jigglers have an option to run for 1, 2, 4, 8, etc hours only.
The use case is, for when i'm remote working, to have the mouse jiggle but only during work hours. If I forget to turn it off, my Teams chat will show as available all night long. Would be nice to set for 8 hours and forget about it (or put a time that it stops)
I totally agree with this feature request. I had written a Java program that set a fixed end time—5 PM in my case—so the mouse jiggler would shut off at that time, no matter when I started it. It helped ensure I logged off on time every day.
The current implementation does not trigger jiggler when you are actually using GLKVM. However, if you directly operate the controlled computer, GLKVM will not be aware of it.
Yeah, thats whats happening to me. im using the controlled computer directly, and the jiggler keeps going off like every 15 seconds and its super annoying. hence it would be nice if we got a customizeable jiggle delay (like 5 minutes) would make it more bearable.
edit: cool just found out you can open a terminal to the ipkvm in the web UI. so cool. im assuming the time unit is seconds? so for 5 minutes, id use 300 right?
also. do i need to restart after making the change or how does it pickup the changes?
+1 for this feature. It would be really nice to have a scheduler that would allow to schedule day of the week, hour of the day, and apply profiles. Profile would configure how long to jiggle, how often, etc. Hope to see it on the RM10 soon.
Will be good to have a feature with two inputs for jiggle time min and max example min 50 max 300. Then jiggle happens between a different random number between the above two every time.
I would also love a scheduler, something as simple as “turn off at 5pm”. I have accidentally left the jiggler feature on all night a few times.
I tried to muddle my way through creating a cron job to turn it off but I am not a linux person and was heavily relying on Gemini assistance, it didn’t go well.
