FEATURE REQUEST On screen caps lock indicator and reset button
Request for an on screen capslock indicator. This allows the user to recognize when caps lock is enabled on UI instead of local computer. Additionally, add an on screen capslock reset button. It can be very small green dot and refresh icon to avoid disturbing the screen. The user may enable or disable via the menu. Please add!
Already on our roadmap and will be included in a future release!
Wanted to give my +1 for this request, as well. Sometimes I will accidentally tap the caps-lock key and it will become out of sync between my host and remote systems, and there doesn’t seem to be a consistent way to reset it. Sometimes I have luck by pressing and holding caps-lock and then switching between the local/remote system.
If its possible to keep the two in sync all the time, that would be another option that works for me.
