Feature Request: Programmatic latest firmware version
My goal is to add the Comet Pro to my list of firmware monitored devices. This requires a website and possibly an API feature, with many devices I parse a pull of the public website for firmware releases and, if available, make an API call to the device itself to see the installed firmware.
Currently, $ curl 'https://dl.gl-inet.com/kvm/rm10/stable' (or some other URL) is geared around browsers and fails for anything not supporting JavaScript, but a tag could produce reasonable content like a JSON listing of releases or even just filenames. This would allow me to store the current latest firmware locally and send a push notification (via Slack and Discord in my case) whenever the latest release gets bumped.
I notice that the pikvm API call curl -k https://{kvm_host}/api/redfish/v1 returns the Redfish version 1.6 on Comet KVM firmware 1.7.2.1. Perhaps there is a better API call to use, or there could be an augmented /api/glinet/v1/version path added?
The use case here is that my RM10 devices are low use, I only log into them when SSH fails to one of the servers. As such, I may end up several releases out of date instead of generating a push notification that an update is available. The API access to the firmware release is a nice-to-have, several of my devices are offline or rarely powered on (for example, I have a Bluetooth bike helmet which has no network access and a BBQ power draft controller which is rarely powered on).
Sorry, we do not officially provide methods to access our firmware servers. If you insist on using it, you can refer to the code we have open-sourced.
You can curl against the JSON endpoint.
curl -s "https://firmware-api.gl-inet.com/cloud-api/model/info?model=rm10" | jq -r '.info[] | select(.stage=="RELEASE") | .version' | head -n 1
1.7.2
That's perfect! Now I can see the latest available release for my devices which is the important bit.
Ideally I'd also love to expose the contents of /etc/version (reformatted as JSON or something a bit more sane) someplace on the device accessible via an API call, I may explore trying to find a safe spot I can deposit a PHP file on the device (so I can do a once-and-done script if it's missing) but I probably need to spin up a device versioning database anyway so storing it off-device is not a show-stopper.
I built a small service for that just a few minutes ago; maybe it's helpful:
That is very nice, I particularly like the consolidated data (/api/all.json). I have some RM1s floating around that I may repurpose. Any chance this could make it to the main site at some point?
Can't tell since I don't work for GL.iNet - I am just a silly :seal: here in the forum. :smiley:
Now I know, the Admon username and shield had me fooled :slight_smile:
As an aside, this is turning into a bigger project where I now have a script to check the latest firmware version and initially will fail to pull the installed version and alert that I should run a setup program (which will likely be needed on cert rotations as well as firmware updates).
This setup program will:
Set a DNS entry for the device with an FQDN
Setup .ssh/authorized_keys
Reformat the /etc/version into JSON and publish it to the webserver
Push valid TLS certs
Whatever else I think of in the future
hey props! nice and clean
