Awesome news! Thank you.
I did a quick test with 4.8.0 (op24) and my amnezia-kmod module vs 4.8.2-beta3 with native support (as clients). Looks like 4.8.2-beta3 is more stable by speed comparing to 4.8.0+kmod.
Great job. Waiting for release.
Just did a quick test from egypt back to germany. The client on my Beryl is working without problems.
Thanks for your testing!
May I know what are the AmneziaWG speeds of 4.8.0+kmod vs 4.8.2-beta3? Is there any difference between Latency, Jitter and Packet Loss, etc.?
May I confirm are you running WireGuard on v4.8.2-beta3 using AmneziaWG profile?
How about the speed?
I’m limited by my Egyptian dsl which is 100 MBit down and 30 MBit up. But i was able to use this completly. Will do more testing next week when back in Germany.
This is not about difference in numbers (they are mostly equal), but during tests beta3 (native support) shows more stable speed (like from 20 to 30 mb/s on my connection) while kmod version jumps from 1mb to 40 and back. Average speed, ping, jitter is the same.
Many thanks for that. Are you able to tell when this feature will be available on the Flint(s) for this great feature to be implemented?
those are some awesome news. are there any plans to release it for other router models ? AXT1800 specifically
Expected on v4.9 firmware for all models.
There is related R&D plan, I think in v4.9.
I tested 4.8.2-beta3 AmneziaWG on my Beryl AX and speed-wise was very good, comparable to the AmneziaWG app I have on macOS (~380MBit/s throughput both up and down). Please if you could push a beta/snapshot for Slate AX (AXT1800) I would be glad to test it!
obfuscation settings:
S1 = 0
S2 = 0
H1 = 1
H2 = 2
H3 = 3
H4 = 4
Jc = 4
Jmin = 40
Jmax = 70
I used the beta version and it works well, much faster than kmod and easy to use. Also now can use my own wireguard server instead of a commercial one. I also feel more at ease with the kill switch working automatically
is there a plan to release beta/snapshot for Slate AX (AXT1800)? that would be appreciated!
Now just small-scale testing, only for MT3000. Sorry.
It will be supported on v4.9, for AXT1800 may be available in next year.
Woah this is good news! I have the MT3000. I will help test because I would prefer to use my AXT1800 tbh.
Have you tried this on the new beta released on 30th September by any chance?
Their changelog is not good at all!
They released a new version without any detail ![]()
How secure is the killswitch. This is my main concern. I absolutely cannot have leakage. I’m considering connect my MT3000 running AWG to my AXT1800 running WG to be on the safe side while testing this beta.
You can always use luci to tune firewall. Simply remove WAN as exit point (LAN —> WAN & WG, leave LAN —> WG only) and you are always on “kill switch” now, it tells router to pass all traffic using one simple exit — WG interface, no any chance to pass data without WG tunnel up.
