Feature Request: SMS Notification for 5G Link Usage
One feature that I had in another 5G solution was the ability to send SMS notifications to a pre-set number with a custom message when the 5G link is being used. I believe this feature would be valuable for our current solution as well.
Here are two major use cases for this feature:
a) Service Providers: Notify customers when the 5G backup link is activated. This message can inform them that the service provider is aware of the issue and is working to resolve it.
b) Regular Users: Alert users when the main link is down, so they can contact their ISP to report the issue. Additionally, this notification can help users manage their data usage since 5G plans often have limited bandwidth and data caps.
Thank you for considering this feature!
Thanks for your advice.
I will collect this request and hand to the PM team to evaluate.
It may be easier and better to implement by informing users which the WAN interface using via email which relates to the GoodCloud Notification feature, anyway let PM team to evaluate.
