Hi, thanks for the amneziaWG support but I’d like to setup VLESS via the same UI as well. I know there is an option via SSH, but it would be simpler if I can add vless url in the same way as other vpn configurations. Can you please consider native support in the UI? thanks.
Thanks for sharing this suggestion.
We’ve noted your request and will discuss it with our product team for future consideration.
