Can RD team consider adding VPN throughout VPN or Tor through VPN?
This can drastically increase security and prevent advanced MITM or prevent ISP to know that you use Tor.
Hmm...
there are different ways one can use it, but in what context do you think its best?
having tor inside the vpn tunnel or outside?
honestly tor itself isn't secure... more than half is donated infra but those exit nodes can contain malicious loggers, therefor i think it makes sense to have the vpn ip visible there.
and vpn already prevents mitm, i did some checking lately but wireguard is very resilent and does not pose a risk to things like replay attacks, there is still some key iteration going on and other things like noise.
Try vpn on the router and use Tor browser in your pc. That may work the best.
