[Feature Request] Wifi schedule: Sunrise, or Sunset
Hi team,
Requesting this - The time of Sunrise and Sunset will be synchronized according to regional realities.
Scenario: want wireless to turn on at sunrise for young one. Sunset etc.
See: How to Set up Schedule, Away Mode, and Timer for Smart Plug/Bulb/Switch in Tapo App | Tapo
Cheers
Well, why does the currently feature about the Wi-Fi schedules not meet your requirements?
You can set the on/off times to approximate sunrise and sunset.
Being able to set and forget would be great.
Can be 4hrs difference.
This requires calling a third-party interface to get the daily sunrise and sunset times, and it may be different every day.
According to evaluate, we assume probably is difficult to coordinate the third-party interface.
But I will keep this requirement in the pool. Thanks again for your advice.
This will be not easy to implement. It has the prerequisite that the router is connected to the internet. Then it has to figure out it's approximate position and then find sundrise/sunset time.
