Feature suggestion for Comet- wireless bridge
Hi, I have a feature suggestion for the Comet series products with wired and wireless functionality. There is a use case where you may only want to connect Comet to the lan using wireless connectivity (which leaves your wired lan port unused). It would be a really amazing feature to allow end users to plug in a wired device which is being controlled on the Comet’s lan port and allow it to have network access by making the Comet serve as a wireless bridge. This would allow you to have network access on controlled devices which do not have a wireless adapter (for instance, certain desktop PC’s) without having to add extra hardware!
I will submit the request to R&D for evaluation. Thanks for your report.
