Feature suggestion VPN server rotation
Hi gl inet
Is it possible to create VPN server rotation function for your routers ( flint, flint 2 ect ) automatically to select a new server from providers of proton , Nordvpn, ect if the VPN starts to run slow or congested the router can check the provider public recommendation API for the best servers in your country no login no credentials - the wireguard private key never changes
https://www.reddit.com/r/GlInet/s/FxPeYbBRob
Thanks for sharing this feature suggestion and the use case.
Currently, the router does not have a reliable method to determine whether a VPN server itself is congested or to decide when an automatic server switch should occur. Connection performance may change for different reasons, so using connection speed alone as the trigger for VPN server rotation may not always provide accurate results. VPN provider recommendations could be useful for server selection, but currently there is no unified method across different VPN providers to support this automatically.
We will record your suggestion and forward it for further evaluation.
