ccchan
hi,
as far as i remember, last time i can install package “ffmpeg” by the default package manager easily.
today i upgraded the ROM, and even I chose keep everything, everything is gone.
now ffmpeg is missing from the packages lists even after i click package update.
I tried to dnld binary from 1 but opkg install *.ipk say the instruction set is not compatible.
pls help, this shd not happen. thanks
ccchan
2
from opkg update it prints:
Updated list of available packages in /var/opkg-lists/glinet_telephony
Downloading https://fw.gl-inet.com/releases/v19.07.7/packages-3.0/mvebu/glinet/Packages.gz
so that the packages are provided by gl-inet and NOT public from openwrt.
so gl-inet please give me back my ffmpeg thanks!
alzhao
4
3.211 firmware
I can install without problem.
ccchan
6
hi, thx for ur reply,
but for my brumeW, the most newest stable version is only
3.203
ccchan
7
ffmpeg is not in brumeW’s v3.203
ccchan
8
i upgraded to v3.203 for the “samba config window”, then cant have ffmpeg.
now downgraded to v3.105 again.
v3.105 have ffmpeg back.
alzhao
9
We will not go back and fix 3.203.
If you have problem with 3.211, you mean let me know.
