I have a GL-AR750S.
I followed the File Share tutorial for SMB 2.0 for windows machines.
I confirmed that the usb storage attached to the router is available though CLI.
I tried both the IP address "\\10.13.38.1" and the hostname “\\GL-AR7550S”
In the case of using the IP I get Windows can’t find ‘\10.13.38.1’
In the case of hostname I get sent to a credentials page. If I try root and my password it says \GL-AR7550S is not accessible. You might ot have permission to use this network resource.
I am out of ideas.
netbios name = |NAME|
display charset = |CHARSET|
interfaces = |INTERFACES|
server string = |DESCRIPTION|
unix charset = |CHARSET|
workgroup = |WORKGROUP|
browseable = yes
deadtime = 30
domain master = yes
encrypt passwords = true
enable core files = no
guest account = nobody
guest ok = yes
invalid users = root
local master = yes
load printers = no
map to guest = Bad User
max protocol = SMB2
min receivefile size = 16384
null passwords = yes
obey pam restrictions = yes
os level = 20
passdb backend = smbpasswd
preferred master = yes
printable = no
security = user
smb encrypt = disabled
smb passwd file = /etc/samba/smbpasswd
socket options = TCP_NODELAY IPTOS_LOWDELAY
syslog = 2
use sendfile = yes
writeable = yes
Is this the complete /etc/samba/smb.conf file? There are no mount points listed as shared.
I tried accessing it from a different computer and it just works now. I am not sure what the difference was. Now my issue is that if I try to write anything to it, it reports that it is out of space, and acts like it is 100% full.
Can you post the complete /etc/samba/smb.conf file? It may show that the share is readonly.
Thanks for taking a look for me:
[global]
netbios name = GL-AR750S
display charset = UTF-8
interfaces = lo br-lan
server string = GL-AR750S-1fe
unix charset = UTF-8
workgroup = WORKGROUP
browseable = yes
deadtime = 30
domain master = yes
guest ok = yes
local master = yes
load printers = no
max protocol = SMB2
os level = 20
printable = no
security = user
syslog = 2
use sendfile = yes
writeable = yes
[homes]
comment = Home Directories
browsable = no
read only = no
create mode = 0750
[GL-Samba]
path = /mnt
read only = no
guest ok = yes
My config file is the same, except I have the line “browseable = yes”
Can you run the command “df” in SSH?
Also run the command “ls -ld /mnt”.
Is the “browsable = yes” in the same location?
I.E., should I change my current setting or add it to the end of the file?
The USB drive is mounted as /mnt/JumpDrive, but you shared /mnt. In the GL.iNet UI → File Sharing, change Current Direcdtory to /mnt/JumpDrive.
It should be okay to add “browsable = yes".
Well shoot, thank you, this worked! I had set it up prior to getting the jump drive working and had left it as is.
