Hi everyone,
so I was trying to set up shares on the router.
The UI is quite ok for basic setup and I guess it's good enough for the most cases.
Tho I have 2 issues that I wanted to discuss.
I went through the documentation but haven't really found anything regarding that File Sharing - GL.iNet Router Docs 3
- Is there a way to make the router "auto discoverable" ?
None of my devices (Android Phone & X-plore File Manager , Win 10 Laptop, Android TV + Kodi) are able to automatically find the router shares, I always had to enter the model hostname manually on PC, which is kinda annoying tbh, bc I never had to do that with other routers before.
Also while the UI is very easy I didnt see any related settings regarding that.
- What speeds can I expect with external HDDs connected to the GL-MT3000 / Beryl AX ?
When I bought it, initial tests were rather slow with 22MB/s. Now that I am only a few m away from the router (and wifi) it went up to ~ 33MB/s.
The cpu is only around 60% so I'm relatively sure the device should be able to handle more than that. (And the wifi is connected with 1Gbit, so that shouldn't be the bottleneck in this case)
