bobch
March 4, 2024, 7:14am
I’m encountering a filesystem mount issue with my GL-XE300 Puli router running OpenWrt. Below are the details of the problem:
Issue: The device fails to boot properly and reboots repeatedly. Upon booting, the following error message is displayed:
[ 2.039932] /dev/root: Can't open blockdev
[ 2.044179] VFS: Cannot open root device "(null)" or unknown-block(0,0): error -6
[ 2.051973] Please append a correct "root=" boot option; here are the available partitions:
[ 2.060617] 1f00 256 mtdblock0
[ 2.060621] (driver?)
[ 2.067375] 1f01 64 mtdblock1
[ 2.067378] (driver?)
[ 2.074140] 1f02 64 mtdblock2
[ 2.074144] (driver?)
[ 2.080915] 1f03 4096 mtdblock3
[ 2.080918] (driver?)
[ 2.087669] 1f04 11904 mtdblock4
[ 2.087672] (driver?)
[ 2.094434] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[ 2.102975] Rebooting in 1 seconds..
Description: The device is unable to mount the root filesystem, resulting in a kernel panic and continuous reboots.
Device Information:
Model: GL-XE300 Puli router
Operating System: OpenWrt
I would appreciate any assistance or guidance on resolving this issue.
admon
March 4, 2024, 7:16am
2
Hey
looks broken to me, but if you are lucky, it’s just the file system itself.
Try to use Uboot to Debrick: Debrick via Uboot - GL.iNet Router Docs 4
If this fails as well, it might be broken and needs to be replaced.
Since you wrote you are using OpenWrt the debrick guide might not work, in that case you have to debrick like the OpenWrt guide says .
alzhao
March 4, 2024, 8:34am
3
Did you flash your own firmware?
If yes, which one?
bobch
March 4, 2024, 9:20am
4
Hi @admon ,
Thank you for your reply!!
I have tried to Debrick via Uboot but it does not help me. Also, I will try the method that you have shared for OpenWrt.
Thanks,
Bobby
bobch
March 4, 2024, 9:23am
5
Hi @alzhao ,
I have flashed the custom OS based on OpenWrt v22.
alzhao
March 4, 2024, 9:27am
6
It just seems a wrong firmware problem. Did you download the firmware from anywhere?
bobch
March 4, 2024, 9:45am
7
@alzhao ,
Based on the OpenWRT v22.03, I have customized the firmware, and it seems some file system issue.
alzhao
March 4, 2024, 9:46am
8
Do you have two files, one .img, one .tar?
bobch
March 4, 2024, 9:59am
9
@alzhao , I have .img and .bin
alzhao
March 4, 2024, 10:01am
10
Use .bin to upgrade in a working openwrt and use .img in uboot.
bobch
March 4, 2024, 10:15am
11
@alzhao ,
Normal upgrade with .bin file does not work. So, I was trying for uboot method with .img file. But still the issue remains.
Scenario Performed:
Flashed the latest standard firmware (4.3.7) from GL-inet website. Using uboot method, upgraded the device (worked)
Later, tried with my custom OS on top of the standard OS using uboot method but did not work.
alzhao
March 4, 2024, 12:04pm
12
Sorry it should be a .tar file to use in normal openwrt update. Do you have it?
bobch
March 5, 2024, 4:15am
13
@alzhao , I do not have a .tar file in my custom build.
alzhao
March 5, 2024, 4:39am
14
Can you give as screenshot of what you have in your firmware folder after compile?
bobch
March 5, 2024, 5:34am
15
@alzhao , attached is the snapshot of the files generated after the build.
bobch
March 8, 2024, 7:21am
16
How can I get the SPI-NAND chip model information used in the GL router XE-300 puli?
alzhao
March 12, 2024, 9:32pm
17
I am not sure why this is needed.
The sysupgrade.bin should work as .tar file which we used. But if it does not work, can you give us more info?
You can email us: support at glinet.biz about details if you don’t want to disclose here.
