Fill hostname for IP Address Reservation from Glinet interface in LuCi
On Marble Firmware 4.5.22 I entered a few IP Addresses in LAN - Address Reservation.
When looking in LuCi Network DHCP, the addresses are listet, but the hostname is empty.
Is this a bug, could the hostname be filled from Glinet interface?
The GL firmware designed what is it, not a bug.
The configuration field in the GL GUI is Description, which is different from the field hostname in Luci, so it appears empty in Luci.
We are aware of this situation and have submitted it to the R&D team for evaluation to see if it will be changed to match Luci's field.
It does not affect your configuration in the GL GUI.
If you need to configure the hostname, please configure in the Luci.
Note as there are different fields, do not use GL GUI and Luci to configure the Address Reservation at the same time.
Yes, I noticed…
After editing the entries in Luci I added a new entry in GL GUI and all my edits were gone :frowning:
Check with cat /etc/config/dhcp in SSH, I think previously saved entries should still be visible.
