When i defining some traffic rules in the firewall even extreme rules like: Source LAN to WAN : reject all protocols have no effect - I also used different positions of the rule or rebooting the router, the rules take no effect
wireless:
config wifi-device 'radio0'
option type 'mac80211'
option path 'platform/soc/c000000.wifi'
option band '5g'
option htmode 'HE80'
option country 'US'
option disabled '0'
option channel 'auto'
option legacy_rates '0'
option channels '36 40 44 48 149 153 157 161 165'
option hwmode '11a'
config wifi-iface 'default_radio0'
option device 'radio0'
option network 'lan'
option mode 'ap'
option encryption 'psk2'
option wds '1'
option isolate '0'
option ssid 'WiFi_2'
option hidden '0'
option key 'XXXXXXXXXX'
config wifi-device 'radio1'
option path 'platform/soc/c000000.wifi+1'
option band '2g'
option country 'US'
option disabled '0'
option htmode 'HE40'
option hwmode '11g'
config wifi-iface 'default_radio1'
option device 'radio1'
option mode 'ap'
option wds '1'
option isolate '0'
option ssid 'WiFi_5'
option hidden '0'
config wifi-iface 'guest5g'
option network 'guest'
option mode 'ap'
option ssid 'GL-AX1800-c3f-5G-Guest'
option guest '1'
option disabled '1'
option wds '1'
option isolate '1'
config wifi-iface 'guest2g'
option mode 'ap'
option ssid 'GL-AX1800-c3f-Guest'
option guest '1'
option disabled '1'
option wds '1'
option isolate '1'
network:
config interface 'loopback'
option device 'lo'
option proto 'static'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config globals 'globals'
option ula_prefix 'xxxx:xxxx:xxxx::/48'
config device
option name 'br-lan'
option type 'bridge'
list ports 'eth1'
list ports 'eth2'
list ports 'eth3'
list ports 'eth4'
option multicast_to_unicast '0'
config device
option name 'eth1'
option macaddr 'xx:xx:xx:xx:xx:xx'
config device
option name 'eth2'
config device
option name 'eth3'
config device
option name 'eth4'
config interface 'lan'
option device 'br-lan'
option ip6assign '60'
option isolate '0'
option ipaddr '10.0.1.1'
config device
option name 'eth0'
config interface 'wan'
option device 'eth0'
option ipv6 '0'
option ipaddr '10.0.0.1'
option gateway '10.0.0.138'
option peerdns '0'
option dns '1.1.1.1 1.0.0.1'
config interface 'wan6'
option proto 'dhcpv6'
option disabled '1'
config switch
option name 'switch0'
option reset '0'
option enable_vlan '0'
config interface 'guest'
option force_link '1'
option ipaddr '192.168.9.1'
option multicast_querier '0'
option igmp_snooping '0'
option isolate '0'
option bridge_empty '1'
config interface 'wwan'
option proto 'dhcp'
config rule 'policy_bypass_vpn'
option mark '0x60000/0x60000'
option lookup '53'
option priority '53'
config rule 'policy_via_vpn'
option mark '0x80000/0x80000'
option lookup '52'
option priority '52'
config rule 'policy_dns'
option mark '0x100000/0x100000'
option lookup '51'
option priority '51'
config interface 'ovpnclient'
option proto 'ovpnclient'
option config '3254_7221'
option disabled '0'
dhcp:
config dnsmasq
option domainneeded '1'
option filterwin2k '0'
option localise_queries '1'
option rebind_localhost '1'
option local '/lan/'
option domain 'lan'
option expandhosts '1'
option nonegcache '0'
option authoritative '1'
option readethers '1'
option leasefile '/tmp/dhcp.leases'
option resolvfile '/tmp/resolv.conf.d/resolv.conf.auto'
option nonwildcard '1'
option localservice '1'
option ednspacket_max '1232'
option rebind_protection '0'
option noresolv '1'
list server '127.0.0.1#3053'
config dhcp 'lan'
option interface 'lan'
option start '100'
option leasetime '12h'
option dhcpv4 'server'
option ra_slaac '1'
list ra_flags 'managed-config'
list ra_flags 'other-config'
option dhcpv6 'disabled'
option ra 'disabled'
option limit '101'
config dhcp 'wan'
option interface 'wan'
option ignore '1'
config odhcpd 'odhcpd'
option maindhcp '0'
option leasefile '/tmp/hosts/odhcpd'
option leasetrigger '/usr/sbin/odhcpd-update'
option loglevel '4'
config domain
option name 'console.gl-inet.com'
option ip '10.0.1.1'
config dhcp 'guest'
option interface 'guest'
option start '100'
option limit '150'
firewall:
config defaults
option syn_flood '1'
option input 'ACCEPT'
option output 'ACCEPT'
option forward 'REJECT'
config zone
option name 'lan'
list network 'lan'
option forward 'ACCEPT'
config zone
option name 'wan'
option mtu_fix '1'
option input 'DROP'
option masq '1'
option network 'wanwan wan6 wwan wan'
config forwarding
option src 'lan'
option dest 'wan'
option enabled '0'
config rule
option src 'wan'
option proto 'udp'
option dest_port '68'
option target 'ACCEPT'
option family 'ipv4'
config rule
option name 'Allow-Ping'
option src 'wan'
option proto 'icmp'
option icmp_type 'echo-request'
config rule
option name 'Allow-IGMP'
option src 'wan'
option proto 'igmp'
config rule
option name 'Allow-DHCPv6'
option src 'wan'
option proto 'udp'
option src_ip 'fc00::/6'
option dest_ip 'fc00::/6'
option dest_port '546'
option family 'ipv6'
config rule
option name 'Allow-MLD'
option src 'wan'
option proto 'icmp'
option src_ip 'fe80::/10'
list icmp_type '130/0'
list icmp_type '131/0'
list icmp_type '132/0'
list icmp_type '143/0'
config rule
option src 'wan'
option proto 'icmp'
list icmp_type 'echo-request'
list icmp_type 'echo-reply'
list icmp_type 'bad-header'
option limit '1000/sec'
config rule
option src 'wan'
option dest '*'
option proto 'icmp'
config rule
option name 'Allow-IPSec-ESP'
option src 'wan'
option dest 'lan'
option proto 'esp'
config rule
option name 'Allow-ISAKMP'
option src 'wan'
option dest 'lan'
option dest_port '500'
option proto 'udp'
config rule
option target 'REJECT'
option dest 'wan'
option src 'lan'
option name 'Test_RULE'
list proto 'all'
config rule
option name 'Support-UDP-Traceroute'
option src 'wan'
option dest_port '33434:33689'
option proto 'udp'
option enabled '0'
config include
config include 'nat6'
option path '/etc/firewall.nat6'
option reload '1'
config include 'gls2s'
option type 'script'
option path '/var/etc/gls2s.include'
option reload '1'
config include 'glblock'
option path '/usr/bin/gl_block.sh'
option reload '1'
config zone
option name 'guest'
option input 'REJECT'
config forwarding
option src 'guest'
option dest 'wan'
option enabled '0'
config rule
option name 'Allow-DHCP'
option src 'guest'
option proto 'udp'
option dest_port '67-68'
config rule
option name 'Allow-DNS'
option src 'guest'
option proto 'tcp udp'
option dest_port '53'
config zone 'ovpnclient'
option name 'ovpnclient'
option forward 'DROP'
option mtu_fix '1'
option network 'ovpnclient'
option enabled '1'
option input 'DROP'
option masq '1'
option masq6 '1'
config forwarding 'ovpnclient2wan'
option src 'ovpnclient'
option dest 'wan'
option enabled '1'
config forwarding 'lan2ovpnclient'
option src 'lan'
option dest 'ovpnclient'
option enabled '1'
config forwarding 'guest2ovpnclient'
option src 'guest'
option enabled '1'
config rule 'sambasharewan'
option src 'wan'
option dest_port '137 138 139 445'
option dest_proto 'tcpudp'
option target 'DROP'
config rule 'sambasharelan'
option src 'lan'
config rule 'glnas_ser'
option src 'wan'
option dest_port '6000-6002'
option dest_proto 'tcp'
config rule 'webdav_wan'
option src 'wan'
option dest_port '6008'
i dont know what i am doing wrong.
