Firmware will have nightly build and put https://dl.gl-inet.com/firmware/snapshots/
You can go to find your model and download and upgrade.
Latest Update
V3.105-Dec 3, 2020: Fix :Bug22、Bug23、Bug24、Bug25、Bug26
V3.105-Nov 21, 2020: Fix :Bug18、Bug19、Bug20、Bug21
V3.105-Nov 18, 2020: Fix :Bug13、Bug14、Bug15、Bug16、Bug17
V3.105-Nov 16, 2020: B1300, S1300, MV1000(W) added to snapshot
V3.105-Nov 11, 2020: This post created
Improvement and New Features:
- Added OpenVPN bridge function.
- OpenVPN upgrade to 2.5
VPN function improvements:
Added VPN CHACHA20 encryption method.
Add WireGuard to support access to the local network.
Main interface icons, add OpenVPN, WireGuard, Tor.
WireGuard page optimization.
OpenVPN page optimization. - Optimize the real-time traffic statistics function, lower CPU usage.
- GoodCloud disconnection problem (MQTT optimization)
- Support NextDNS personal ID
Bug Fix
1.Memory leak for itertf process.
2.VPN firewall should be rejected by default.
3.Port 53 is opened on the firewall before, will be closed by default.
4.Update the ca-bundle and ca-certificates software packages to solve the problem of certificate expiration.
5.When enabling WireGuard Server and DDNS simultaneously, the devices that connect to the WireGuard configuration cannot access Admin Panel via DDNS URL.
6.Connect to Tor and enable “DNS on all clients”, causes DNS leaks.
7.Cannot connect to Mullvad WireGuard with a mobile SIM card.
8.The screen status of Mudi (GL-E750) is not updated.
9.Amarok (GL-X1200) Dual module IP address exchange problem.
10.SSH encryption does not support special characters.
11.After configuring DNS on Luci, the DNS page on the Admin Panel cannot be opened.
12.Wireguard routing rules optimization.
13.Use ovpn to upload too many configuration files, unable to click “Apply”
14.The web management page displays an error.
15.Static IP address binding, modification of the IP cannot detect legitimacy.
16.Mango (GL-MT300N-V2) cannot use luci page.
17.Mango (GL-MT300N-V2) cannot detect Tethering device problems.
18.Firmware upgrade detection abnormal problem.
19.Optimize the issue of mqtt log output level.
20.Firmware upgrade, keep the previous configuration, the old password can not log in.
21.Adguard Home update failure problem.
22.firmware upgrade verification problem
23.Integrated MX35LF1GE4AB patch.
24.Integrating iOS14 cannot get traffic patches
25.The number of Amarok (GL-X1200) wireless connections is limited
26.Wireguard upgrade to the latest version.
