When I upgrade to 3.105 on my mifi, I can’t connect to LTE. I am not using the quectel module. I am using a Fobicom module. It was working fine with 3.029. I see this error in the logs.
Mon Dec 7 07:42:40 2020 daemon.notice netifd: Interface ‘modem_1_1_2’ is now down
Mon Dec 7 07:42:40 2020 daemon.notice netifd: Interface ‘modem_1_1_2’ is setting up now
Mon Dec 7 07:42:44 2020 daemon.notice netifd: modem_1_1_2 (9882): find: -name requires an argument
Mon Dec 7 07:42:44 2020 daemon.notice netifd: modem_1_1_2 (9882): cat: can’t open ‘/tmp/modem./signal’: No such file or directory
Mon Dec 7 07:42:45 2020 daemon.notice netifd: modem_1_1_2 (10085): /usr/sbin/pppd: unrecognized option ‘/dev’
Mon Dec 7 07:42:45 2020 daemon.err pppd[10085]: unrecognized option ‘/dev’
Mon Dec 7 07:42:45 2020 daemon.notice netifd: modem_1_1_2 (10085): pppd version 2.4.7
Mon Dec 7 07:42:45 2020 daemon.notice netifd: modem_1_1_2 (10085): Usage: /usr/sbin/pppd [ options ], where options are:
Mon Dec 7 07:42:45 2020 daemon.notice netifd: modem_1_1_2 (10085): Communicate over the named device
Mon Dec 7 07:42:45 2020 daemon.notice netifd: modem_1_1_2 (10085): Set the baud rate to
Mon Dec 7 07:42:45 2020 daemon.notice netifd: modem_1_1_2 (10085): : Set the local and/or remote interface IP
Mon Dec 7 07:42:45 2020 daemon.notice netifd: modem_1_1_2 (10085): addresses. Either one may be omitted.
Mon Dec 7 07:42:45 2020 daemon.notice netifd: modem_1_1_2 (10085): asyncmap Set the desired async map to hex
Mon Dec 7 07:42:45 2020 daemon.notice netifd: modem_1_1_2 (10085): auth Require authentication from peer
Mon Dec 7 07:42:45 2020 daemon.notice netifd: modem_1_1_2 (10085): connect
Invoke shell command
to set up the serial line
Mon Dec 7 07:42:45 2020 daemon.notice netifd: modem_1_1_2 (10085): crtscts Use hardware RTS/CTS flow control
Mon Dec 7 07:42:45 2020 daemon.notice netifd: modem_1_1_2 (10085): defaultroute Add default route through interface
Mon Dec 7 07:42:45 2020 daemon.notice netifd: modem_1_1_2 (10085): file Take options from file
Mon Dec 7 07:42:45 2020 daemon.notice netifd: modem_1_1_2 (10085): modem Use modem control lines
Mon Dec 7 07:42:45 2020 daemon.notice netifd: modem_1_1_2 (10085): mru Set MRU value to for negotiation
I am running a snapshot of 3.105 so the actual 3.105 release is not detected, having the same version number.
How can I upgrade it then? On the official page I could only find the u-boot images, but I’d rather not use that.
In the release notes V3.105 for Slate is support of russian language. I have updated my Slate to 1.05 with last release. There is no russian language.
Did I do something wrong or misunderstood?
Thank you in advance!
Hi… I can’t remember if I updated from the beta to the release version. Can someone please confirm that the compile time here corresponds with the 3.105 final release?
