Firmware 3.201, 3.203 Release Notes and Upgrade Q&A
You can try to install luci-theme-bootstramp
Thanks for the fast reply @alzhao! I will try that when I get home tonight.
This clearly had an impact, I guess it’s a progress. Now instead of the raw text in the browser window I get a page with the GL-AR300M banner, indicating below the banner:
Component not present.
Powered by LuCI openwrt-19.07 branch (git-21.044.30835-34e0d65) / OpenWrt 19.07.7 r11306-c4a6851c72
I can SSH into the machine and retrieve log files or run diagnostics if that helps to debug this issue. It’s just that I have no clue where to start to troubleshoot this.
EDIT:
OK, guess what: I had to install luci! Somehow that got removed, either during the upgrade or the installation or uninstall of luci-app-wifischedule. Anyhow, I’m back up and running, thanks a lot!
EDIT2:
Stupid me, I just now read the release notes more carefully. It’s clearly indicated that luci has to be installed manually!
is it possible to add the compatibility with the alfa usb awus1900 RTL8814AU int the firmware of the brume ?
After installation of 3.201 (w/o preserving any old conf)on mt-300n-v2 I realized that something is wrong with memory allocation. I cannot install almost anything. I’ve repeated installation a couple of times.
root@GL-MT300N-V2:~# df -h
Filesystem Size Used Available Use% Mounted on
/dev/root 10.5M 10.5M 0 100% /rom
tmpfs 60.8M 124.0K 60.7M 0% /tmp
tmpfs 60.8M 128.0K 60.7M 0% /tmp/root
tmpfs 512.0K 0 512.0K 0% /dev
/dev/mtdblock6 3.8M 792.0K 3.0M 21% /overlay
overlayfs:/overlay 3.8M 792.0K 3.0M 21% /
On my USB150 /overlay is over 5 MB.
On my regular routers (e.g. netgear) /rom is about 2MB.
You have 3.0M available. This is totally normal
on my usb150 /overlay is over 5MB, on MT300N-V2 is less that 4MB. Is it normal? I cannot even install gl-tor.
https://openwrt.org/toh/gl.inet/gl.inet_gl-mt300n_v2
/dev/root- around 2.3 MiB rootfs_data - around 12 MiB
Is it possible to integrate for the brume the compatibility with the usb alfa awus1900 in a futur update ?
Hi Guys,
I put version 3.203_beta3 here
Only a few models have been updated, with the main changes as follows:
B1300,S1300, and AP1300 will support QSDK11 stably.
MV1000 upgraded to OpenWrt 19.07.7.
E750: Fixed a BUG where the OpenVPN connection status was displayed incorrectly on the  LCD.
XE300: Fixed a BUG where the manual configuration of the modem was always overwritten in the 3.201 firmware.
X1200 fixes probabilistic upgrade failure caused by watchdog based on 3.201.
About the WiFi FragAttacks security vulnerability, fixing it in OpenWrt 19.07.7 and QSDK11 is a bit cumbersome, we need some time and will fix it in a later beta release.
We are planning the firmware 4.x, which will be based on OpenWrt 21.x and GL-SDK4.x integration firmware. It is expected to be released in October, we hope to bring you a better experience. :wink:
Thank you :slight_smile:
Trying…
Great piece of firmware ! The S1300 works really fantastic with it :slight_smile:
May is ending soon… waiting for firmware release 3.203 coming … :upside_down_face:
The only thing i noticed last night is, that the DLNA Server did not work after a reboot of the router… Even a rescan via ssh-terminal did not changed anything.
would like to give a feedback regarding 3.20x firmwares. with Luci being excluded out of default installation, people who depend on VLAN for internet connection will be unable to set up a connection.
please set up VLAN option within the GL GUI if Luci is not included.
You can still install luci and set up vlan.
We will make vlan in the default firmware in firmware 4.x
no i can’t. i need internet to install luci, i need VLAN for internet.
OK understand. Vlan should be a basic feature and should have an UI in the firmware.
I saw that the repeater problems are pending and I am not sure if my problem https://forum.gl-inet.com/t/wifi-connection-problems-on-gl-mt300n-v2 is related, but if I could help with providing more details or some test please let me know.
Best regards
Marcus
I have upgraded my 2 GL-B1300 to the 3.203 beta 3, I have some bugs:
  • In the ‘Client’ tab I only see 2 devices while there are many connected and visible in the ‘Mesh’ tab
  • Same problem on GoodCloud I can’t see all clients
  • Deleting offline devices does not work in the ‘Clients’ tab
  • I can’t change the protection of the Wifi Mesh (I can only fill in the name and password but not the protection as in the ‘Guest wifi’ tab). This is problematic because one of the computers can’t connect to the router (Windows 10 : can’t connect to this network). I activated the guest wifi without protection and now it can connect. (and in Lucy interface in see ‘Encryption: none’ in all SSID in Network > Wifi > Wifi overview while there are a password in my wifi network)
  • Workaround is to use the Glinet app on smartphone to change WPA to WPA/WPA (it’s the only interface wo we can do that
  • When I disabled Mesh guest network, only 2.4ghz is stopped and I can’t stop the 5Ghz guest network
