Firmware 4.11.x Memory Leak MT6000 & MT3000 Mesh Enabled
Hi All,
I've found an issue with the latest 4.11.x firmwares. It seems that with Mesh enabled in /tmp/beerocks/logs log files are being generated at an alarming rate until the file system fills up and the routers crash. I've had to disable the Mesh functionallity for now. My routers lasted about 36 hours before crashing.
I first noticed this because i could not complete a firmware update due to insufficent space (in /tmp aparently). when i removed the log files i was able to update.
Has anyone else has issues? I see a lot of posts regarding 4.11.x firmware crashes after a few hours, i wonder if they are all related.
Thank you for your feedback.
Please refer to the following reply for details about the issue and the temporary workaround.
Also, if possible, could you please run the following commands on the affected device before clearing the logs or rebooting, and share the output with us?
uptime
ls -agh /tmp/beerocks/logs/
du -sh /tmp/beerocks/logs/
Thank you for your understanding and support.
Hi @charles2, sorry but i've cleared the logs.
I have two Flint 2 in mesh running and having the same problem. At the moment I let them both reboot every day at 4am. Here is the log:
root@Router:~# ls -agh /tmp/beerocks/logs/
drwxr-xr-x 2 root 2.6K Nov 26 16:14 .
drwxr-xr-x 4 root 200 Nov 26 03:55 ..
-rw-r--r-- 1 root 976.8K Nov 26 05:55 beerocks_agent.20261126_035543.log
-rw-r--r-- 1 root 976.9K Nov 26 07:58 beerocks_agent.20261126_055544.log
-rw-r--r-- 1 root 976.8K Nov 26 10:03 beerocks_agent.20261126_075846.log
-rw-r--r-- 1 root 976.8K Nov 26 12:07 beerocks_agent.20261126_100319.log
-rw-r--r-- 1 root 976.8K Nov 26 14:10 beerocks_agent.20261126_120746.log
-rw-r--r-- 1 root 976.8K Nov 26 16:14 beerocks_agent.20261126_141019.log
-rw-r--r-- 1 root 77.0K Nov 26 16:24 beerocks_agent.20261126_161436.log
lrwxrwxrwx 1 root 34 Nov 26 16:14 beerocks_agent.log -> beerocks_agent.20261126_161436.log
-rw-r--r-- 1 root 1.4K Nov 26 16:14 beerocks_agent_std.log
-rw-r--r-- 1 root 765.7K Nov 26 16:24 beerocks_ap_manager_ra0.20261126_035544.log
lrwxrwxrwx 1 root 43 Nov 26 03:55 beerocks_ap_manager_ra0.log -> beerocks_ap_manager_ra0.20261126_035544.log
-rw-r--r-- 1 root 12 Nov 26 03:55 beerocks_ap_manager_ra0_std.log
-rw-r--r-- 1 root 75.0K Nov 26 16:24 beerocks_ap_manager_rax0.20261126_035544.log
lrwxrwxrwx 1 root 44 Nov 26 03:55 beerocks_ap_manager_rax0.log -> beerocks_ap_manager_rax0.20261126_035544.log
-rw-r--r-- 1 root 12 Nov 26 03:55 beerocks_ap_manager_rax0_std.log
-rw-r--r-- 1 root 976.6K Nov 26 12:04 beerocks_backhaul.20261126_035543.log
-rw-r--r-- 1 root 508.8K Nov 26 16:24 beerocks_backhaul.20261126_120436.log
lrwxrwxrwx 1 root 37 Nov 26 12:04 beerocks_backhaul.log -> beerocks_backhaul.20261126_120436.log
-rw-r--r-- 1 root 64 Nov 26 03:55 beerocks_backhaul_std.log
-rw-r--r-- 1 root 976.7K Nov 26 05:35 beerocks_controller.20261126_035543.log
-rw-r--r-- 1 root 976.7K Nov 26 07:22 beerocks_controller.20261126_053552.log
-rw-r--r-- 1 root 976.7K Nov 26 08:58 beerocks_controller.20261126_072204.log
-rw-r--r-- 1 root 976.9K Nov 26 10:45 beerocks_controller.20261126_085842.log
-rw-r--r-- 1 root 976.8K Nov 26 12:27 beerocks_controller.20261126_104519.log
-rw-r--r-- 1 root 976.8K Nov 26 14:05 beerocks_controller.20261126_122730.log
-rw-r--r-- 1 root 976.8K Nov 26 15:44 beerocks_controller.20261126_140537.log
-rw-r--r-- 1 root 363.4K Nov 26 16:24 beerocks_controller.20261126_154438.log
lrwxrwxrwx 1 root 39 Nov 26 15:44 beerocks_controller.log -> beerocks_controller.20261126_154438.log
-rw-r--r-- 1 root 1.4K Nov 26 15:44 beerocks_controller_std.log
-rw-r--r-- 1 root 976.7K Nov 26 04:15 beerocks_monitor_ra0.20261126_035544.log
-rw-r--r-- 1 root 976.8K Nov 26 04:28 beerocks_monitor_ra0.20261126_041541.log
-rw-r--r-- 1 root 976.7K Nov 26 04:42 beerocks_monitor_ra0.20261126_042858.log
-rw-r--r-- 1 root 976.7K Nov 26 04:55 beerocks_monitor_ra0.20261126_044215.log
-rw-r--r-- 1 root 976.7K Nov 26 05:08 beerocks_monitor_ra0.20261126_045532.log
-rw-r--r-- 1 root 976.7K Nov 26 05:22 beerocks_monitor_ra0.20261126_050849.log
-rw-r--r-- 1 root 976.7K Nov 26 05:35 beerocks_monitor_ra0.20261126_052206.log
-rw-r--r-- 1 root 976.8K Nov 26 05:48 beerocks_monitor_ra0.20261126_053522.log
-rw-r--r-- 1 root 976.7K Nov 26 06:01 beerocks_monitor_ra0.20261126_054840.log
-rw-r--r-- 1 root 976.7K Nov 26 06:15 beerocks_monitor_ra0.20261126_060157.log
-rw-r--r-- 1 root 976.7K Nov 26 06:28 beerocks_monitor_ra0.20261126_061513.log
-rw-r--r-- 1 root 976.8K Nov 26 06:41 beerocks_monitor_ra0.20261126_062830.log
-rw-r--r-- 1 root 976.7K Nov 26 06:55 beerocks_monitor_ra0.20261126_064148.log
-rw-r--r-- 1 root 976.7K Nov 26 07:08 beerocks_monitor_ra0.20261126_065504.log
-rw-r--r-- 1 root 976.7K Nov 26 07:21 beerocks_monitor_ra0.20261126_070821.log
-rw-r--r-- 1 root 976.7K Nov 26 07:34 beerocks_monitor_ra0.20261126_072138.log
-rw-r--r-- 1 root 976.7K Nov 26 07:48 beerocks_monitor_ra0.20261126_073455.log
-rw-r--r-- 1 root 976.7K Nov 26 08:01 beerocks_monitor_ra0.20261126_074812.log
-rw-r--r-- 1 root 976.8K Nov 26 08:14 beerocks_monitor_ra0.20261126_080128.log
-rw-r--r-- 1 root 976.8K Nov 26 08:28 beerocks_monitor_ra0.20261126_081447.log
-rw-r--r-- 1 root 976.7K Nov 26 08:41 beerocks_monitor_ra0.20261126_082804.log
-rw-r--r-- 1 root 976.7K Nov 26 08:54 beerocks_monitor_ra0.20261126_084121.log
-rw-r--r-- 1 root 976.7K Nov 26 09:07 beerocks_monitor_ra0.20261126_085438.log
-rw-r--r-- 1 root 976.7K Nov 26 09:21 beerocks_monitor_ra0.20261126_090755.log
-rw-r--r-- 1 root 976.7K Nov 26 09:34 beerocks_monitor_ra0.20261126_092113.log
-rw-r--r-- 1 root 976.7K Nov 26 09:47 beerocks_monitor_ra0.20261126_093430.log
-rw-r--r-- 1 root 976.9K Nov 26 10:01 beerocks_monitor_ra0.20261126_094746.log
-rw-r--r-- 1 root 976.7K Nov 26 10:14 beerocks_monitor_ra0.20261126_100103.log
-rw-r--r-- 1 root 976.7K Nov 26 10:27 beerocks_monitor_ra0.20261126_101420.log
-rw-r--r-- 1 root 976.7K Nov 26 10:40 beerocks_monitor_ra0.20261126_102737.log
-rw-r--r-- 1 root 976.7K Nov 26 10:54 beerocks_monitor_ra0.20261126_104054.log
-rw-r--r-- 1 root 976.7K Nov 26 11:07 beerocks_monitor_ra0.20261126_105411.log
-rw-r--r-- 1 root 976.7K Nov 26 11:20 beerocks_monitor_ra0.20261126_110727.log
-rw-r--r-- 1 root 976.7K Nov 26 11:34 beerocks_monitor_ra0.20261126_112045.log
-rw-r--r-- 1 root 976.7K Nov 26 11:47 beerocks_monitor_ra0.20261126_113402.log
-rw-r--r-- 1 root 976.7K Nov 26 12:00 beerocks_monitor_ra0.20261126_114719.log
-rw-r--r-- 1 root 976.7K Nov 26 12:13 beerocks_monitor_ra0.20261126_120036.log
-rw-r--r-- 1 root 976.7K Nov 26 12:27 beerocks_monitor_ra0.20261126_121353.log
-rw-r--r-- 1 root 976.7K Nov 26 12:40 beerocks_monitor_ra0.20261126_122703.log
-rw-r--r-- 1 root 976.7K Nov 26 12:53 beerocks_monitor_ra0.20261126_124019.log
-rw-r--r-- 1 root 976.7K Nov 26 13:06 beerocks_monitor_ra0.20261126_125336.log
-rw-r--r-- 1 root 976.7K Nov 26 13:20 beerocks_monitor_ra0.20261126_130654.log
-rw-r--r-- 1 root 976.7K Nov 26 13:33 beerocks_monitor_ra0.20261126_132013.log
-rw-r--r-- 1 root 976.9K Nov 26 13:46 beerocks_monitor_ra0.20261126_133330.log
-rw-r--r-- 1 root 976.7K Nov 26 14:00 beerocks_monitor_ra0.20261126_134649.log
-rw-r--r-- 1 root 976.7K Nov 26 14:13 beerocks_monitor_ra0.20261126_140006.log
-rw-r--r-- 1 root 976.7K Nov 26 14:26 beerocks_monitor_ra0.20261126_141322.log
-rw-r--r-- 1 root 976.7K Nov 26 14:40 beerocks_monitor_ra0.20261126_142640.log
-rw-r--r-- 1 root 976.7K Nov 26 14:53 beerocks_monitor_ra0.20261126_144001.log
-rw-r--r-- 1 root 976.7K Nov 26 15:06 beerocks_monitor_ra0.20261126_145320.log
-rw-r--r-- 1 root 976.7K Nov 26 15:20 beerocks_monitor_ra0.20261126_150639.log
-rw-r--r-- 1 root 976.7K Nov 26 15:33 beerocks_monitor_ra0.20261126_152000.log
-rw-r--r-- 1 root 976.7K Nov 26 15:46 beerocks_monitor_ra0.20261126_153318.log
-rw-r--r-- 1 root 977.0K Nov 26 15:59 beerocks_monitor_ra0.20261126_154637.log
-rw-r--r-- 1 root 976.7K Nov 26 16:13 beerocks_monitor_ra0.20261126_155958.log
-rw-r--r-- 1 root 821.5K Nov 26 16:24 beerocks_monitor_ra0.20261126_161316.log
lrwxrwxrwx 1 root 40 Nov 26 16:13 beerocks_monitor_ra0.log -> beerocks_monitor_ra0.20261126_161316.log
-rw-r--r-- 1 root 10.4K Nov 26 16:13 beerocks_monitor_ra0_std.log
-rw-r--r-- 1 root 976.9K Nov 26 04:14 beerocks_monitor_rax0.20261126_035544.log
-rw-r--r-- 1 root 976.9K Nov 26 04:32 beerocks_monitor_rax0.20261126_041422.log
-rw-r--r-- 1 root 976.8K Nov 26 04:50 beerocks_monitor_rax0.20261126_043223.log
-rw-r--r-- 1 root 976.7K Nov 26 05:08 beerocks_monitor_rax0.20261126_045024.log
-rw-r--r-- 1 root 976.8K Nov 26 05:26 beerocks_monitor_rax0.20261126_050825.log
-rw-r--r-- 1 root 976.7K Nov 26 05:44 beerocks_monitor_rax0.20261126_052626.log
-rw-r--r-- 1 root 976.8K Nov 26 06:02 beerocks_monitor_rax0.20261126_054427.log
-rw-r--r-- 1 root 976.7K Nov 26 06:20 beerocks_monitor_rax0.20261126_060228.log
-rw-r--r-- 1 root 976.9K Nov 26 06:38 beerocks_monitor_rax0.20261126_062027.log
-rw-r--r-- 1 root 976.8K Nov 26 06:56 beerocks_monitor_rax0.20261126_063828.log
-rw-r--r-- 1 root 976.8K Nov 26 07:14 beerocks_monitor_rax0.20261126_065628.log
-rw-r--r-- 1 root 976.7K Nov 26 07:32 beerocks_monitor_rax0.20261126_071427.log
-rw-r--r-- 1 root 976.7K Nov 26 07:50 beerocks_monitor_rax0.20261126_073226.log
-rw-r--r-- 1 root 976.7K Nov 26 08:08 beerocks_monitor_rax0.20261126_075024.log
-rw-r--r-- 1 root 976.8K Nov 26 08:26 beerocks_monitor_rax0.20261126_080822.log
-rw-r--r-- 1 root 976.7K Nov 26 08:44 beerocks_monitor_rax0.20261126_082620.log
-rw-r--r-- 1 root 976.7K Nov 26 09:02 beerocks_monitor_rax0.20261126_084421.log
-rw-r--r-- 1 root 976.7K Nov 26 09:20 beerocks_monitor_rax0.20261126_090222.log
-rw-r--r-- 1 root 976.9K Nov 26 09:38 beerocks_monitor_rax0.20261126_092022.log
-rw-r--r-- 1 root 976.9K Nov 26 09:56 beerocks_monitor_rax0.20261126_093823.log
-rw-r--r-- 1 root 976.9K Nov 26 10:14 beerocks_monitor_rax0.20261126_095624.log
-rw-r--r-- 1 root 976.8K Nov 26 10:32 beerocks_monitor_rax0.20261126_101426.log
-rw-r--r-- 1 root 976.7K Nov 26 10:50 beerocks_monitor_rax0.20261126_103227.log
-rw-r--r-- 1 root 976.8K Nov 26 11:08 beerocks_monitor_rax0.20261126_105028.log
-rw-r--r-- 1 root 976.7K Nov 26 11:26 beerocks_monitor_rax0.20261126_110829.log
-rw-r--r-- 1 root 976.8K Nov 26 11:44 beerocks_monitor_rax0.20261126_112629.log
-rw-r--r-- 1 root 976.7K Nov 26 12:02 beerocks_monitor_rax0.20261126_114430.log
-rw-r--r-- 1 root 976.8K Nov 26 12:20 beerocks_monitor_rax0.20261126_120231.log
-rw-r--r-- 1 root 976.7K Nov 26 12:38 beerocks_monitor_rax0.20261126_122027.log
-rw-r--r-- 1 root 976.7K Nov 26 12:56 beerocks_monitor_rax0.20261126_123825.log
-rw-r--r-- 1 root 976.7K Nov 26 13:14 beerocks_monitor_rax0.20261126_125624.log
-rw-r--r-- 1 root 976.7K Nov 26 13:32 beerocks_monitor_rax0.20261126_131412.log
-rw-r--r-- 1 root 976.7K Nov 26 13:50 beerocks_monitor_rax0.20261126_133209.log
-rw-r--r-- 1 root 976.9K Nov 26 14:08 beerocks_monitor_rax0.20261126_135009.log
-rw-r--r-- 1 root 976.8K Nov 26 14:26 beerocks_monitor_rax0.20261126_140810.log
-rw-r--r-- 1 root 976.7K Nov 26 14:44 beerocks_monitor_rax0.20261126_142610.log
-rw-r--r-- 1 root 976.7K Nov 26 15:02 beerocks_monitor_rax0.20261126_144410.log
-rw-r--r-- 1 root 976.7K Nov 26 15:20 beerocks_monitor_rax0.20261126_150208.log
-rw-r--r-- 1 root 976.7K Nov 26 15:38 beerocks_monitor_rax0.20261126_152009.log
-rw-r--r-- 1 root 976.8K Nov 26 15:56 beerocks_monitor_rax0.20261126_153810.log
-rw-r--r-- 1 root 976.8K Nov 26 16:14 beerocks_monitor_rax0.20261126_155610.log
-rw-r--r-- 1 root 558.8K Nov 26 16:24 beerocks_monitor_rax0.20261126_161410.log
lrwxrwxrwx 1 root 41 Nov 26 16:14 beerocks_monitor_rax0.log -> beerocks_monitor_rax0.20261126_161410.log
-rw-r--r-- 1 root 7.7K Nov 26 16:14 beerocks_monitor_rax0_std.log
root@Router:~# du -sh /tmp/beerocks/logs/
108.4M /tmp/beerocks/logs/
root@Router:~#
No worries at all, and thank you for letting us know.
Thank you for providing the logs and details of your Mesh setup.
This information will help us investigate the issue further, and we appreciate your support.
