Just a follow up. Obviously I can’t see the key rotation from Wireguard happening anymore, key rotation which happens every two minutes since I did not modify the defaults. What would happen if the router stopped rotating the keys every two minutes? Would the Wireguard server allow such thing to happen or would my connection drop?
After a handshake is completed, with a message from initiator to responder and then responder back to initiator, the initiator may then send encrypted session packets, but the responder cannot. The responder must wait to use the new session until it has recieved one encrypted session packet from the initiator, in order to provide key confirmation. Thus, until the responder receives that first packet using the newly established session, it must either queue up packets to be sent later, or use the previous session, if one exists and is valid. Therefore, after the initiator receives the response from the responder, if it has no data packets immediately queued up to send, it should send an empty packet, so as to provide this confirmation.
Ok thank you for the reply. Can you confirm the key rotation on Wireguard on GL.inet routers happens every two minutes or so? The way I understand this is, if either the initiator or responder fail to re-establish a new handshake after two minutes, basically no encrypted data can be exchanged by either the initiator or responder which would be evident by a loss of internet connection of ones device. Is this correct?
“Or so” is correct. It’s a stateless protocol so it’ll just pick up the new keys in the next exchange of packets. It’s a bit of ‘best practice’ to include a KeepAlive directive in the settings of 25 seconds for just this sort of thing on both endpoints… & WG is handled at the kernel level. You’re fine.
