Firmware 4.2.x is out as snapshot firmware
Just upgrade my Flint to 4.2.0 snapshot firmware and find out some new features integrated: (nice)
Parental Control:
ZeroTier:
圖片
TailScale:
Seems 4.2 fix my 5GHz WiFi, now my iPhones don’t have problem connecting to it while using WPA3 Auth.
What do you mean fixed WiFi? Fixed slow Wifi speed?
How is the stability, usually don’t run snapshots like.
@K3rn3l_Ku5h I mean on 4.1.0 any release from 1 to 6, when I’m using WPA3 on 5GHz WiFi, all my apple devices won’t connect to it, it just keep Connection failed.
But when I try on 4.2.0 snapshot the problem now is gone.
The wifi speed doesn’t effected
How does the parental control work?
GL.iNET services are set by default to use the VPN.(opposite of what was done in past)
Sqm package won’t install in LuCi. Gives a invalid kernel, but is the 4.4.60 dependency. Not sure if GL.iNet tuned the CAKE QOS on the router but it has gotten much better and manually tuning with sqm is nothing but wasted time and effort.
Come on fix this 5g, speeds are proper causing problems here
Does this revert the wifi speed to the expected ful amount t 5g
It seems that VPN cascading on flint is not working bit disappointing.
It should work without problems.
Tested on flint is not working. After toggle on the vpn client then no internet access on my phone. Once toggle off the vpn client then my phone can access the vpn server.
I will have a check. Thanks for reporting.
Hi, is your VPN dashboard global option like the following?
VPN Client:
VPN Server:
Tested Slate AX is working. Only flint not working so far.
WireGuard VPN Cascading did not work when I was testing Brume 2 because of a conflict on Port 51820. I changed the WireGuard server on the router to use Port 51821 and then it worked. Maybe that is the same issue on Flint.
Tested changed port instead 51820, same cannot access vpn server. Once off the vpn client then able to access the vpn server on my phone.
The vpn cascading function is not working on flint.
Did you make changes in the VPN dashboard to global rules and proxy rules.
and you are using the cascading document for set up.
Yes, i did but unfortunately
Sometimes, i have thought why it is so difficult to use the features on the product
