Today I installed the firmware version 4.4.10. The 5Ghz WiFi has been severely impacted. I am suspecting the driver but haven't investigated it yet.
Can we get some specific information?
We tested it. There's no problem
I really don’t know what’s the cause… after downgrading to 4.4.9, the WiFi speed back to normal.
How much will it go down?
What are the numbers? How did you test? What did you test?
1/3 speed degradation: from 650 mbps to 200 mbps.
Connecting an iPhone to the default 5g WiFi network with default settings. Then using speed test dot com.
Did you try to reset your unit as well?
As I said I already downgraded. But to answer your question when I tested the WiFi, it was flashed using uboot with default settings.
