https://dl.gl-inet.com/?model=ax1800&type=beta
BIG Upgrade
V4.5.0 - Oct 09,2023
Bark
Added Bark parental control feature.
Black_white_list
Fixed the issue where blacklist configurations were not synchronized when upgrading from low versions to 4.4 or later versions.
Fixed the issue where security options were missing when upgrading from version 4.4.x to 4.5 using reserved configurations.
Full Cone NAT
Added Full Cone NAT functionality.
LAN
Optimized LAN function to support switching DHCP on/off and configuring common DHCP parameters.
Decoupled internal and guest networks IP addresses and DHCP functions, allowing independent configuration of DHCP servers.
IPoE
Added support for IPoE, including DHCP and static dial-up with VLAN ID configuration.
Kmwan
Restructured mwan3, renamed it as kmwan.
Languages
Added community-based language packs, allowing users to manually add them.
Modem
Adjusted SMS functionality.
Supports EM060K upgrades.
Fixed the issue where the TTL setting does not take effect.
Fixed the issue where B66 and B71 bands are locked incorrectly.
Fixed the issue where the TTL setting does not take effect when using 3G protocols.
Multi-sign-on
Added additional multi-sign-on restrictions.
Nas
Fixed a security vulnerability in NAS.
Fixed issues with user deletion and shared folder deletion that were abnormal.
Parental Control
Optimized parental control logic.
Fixed the issue where Failover is not effective when enabling parental control under the 'drop-in gateway' mode.
Repeater
Fixed the issue where continuous DFS scans occur when all interfaces are turned off.
Fixed the issue where WiFi restarts itself repeatedly when operating in a DFS channel as a repeater.
RS485
Added RS485 functionality.
Rtty
Fixed RTTY abnormal disconnection issue.
Security
Added new Security configuration page.
VPN
Fixed OpenVPN encryption issues by adding support for 'askpass' to authenticate users in configurations.
Optimized VPN Dashboard by adding a switch for client-to-client communication when using WireGuard servers.
Optimized failover handling when switching between VPNs.
Optimized OpenVPN to support TAP S2S mode.
Added a method for deleting VPN account passwords.
Fixed an issue where setting an OpenVPN configuration would prevent access to the VPN server's WAN port.
Fixed DNS leak issues.
Fixed an issue where VPN configurations were not applied correctly after enabling VPNs.
UI
Added a new network advanced setting in the frontend.
Updated language files and pulled in updated translation scripts.
Display the 'OpenDDNS' button only when the 'Enable DNS' option is checked in the settings page.
Added Bark translation and updated the parent control UI.
Added rs485 UI and translation.
Upgrade
Added gray testing design, and added RC version subscription and upgrade.
Optimized upgrade status and timeout time.
Fixed interface errors.
Wifi
Fixed the issue where WiFi failed to start for the first time after upgrading.
Added temperature protection settings.
