Firmware 4.7 Wireguard NORDVPN no Data
I have updated to the 4.7 beta because I can finally use Wirguard for NordVPN.
It worked really good until today. I was connected to a Server. But I noticed that I forgot to add one of the Servers I really wanted to be included in the Server list so I tried to add that one. After I tried it said that there is No Data (see picture). I thought that it might been an issue with the specific Server so I went back and only added the Servers I had before that. But all of a sudden it stayed with "No Data".
I then tried to only add one Server (tried a few solo Server Locations). None of them worked it always stayed with the No data error. After that I have done a reset of the firmware of the router and I also went to Nord and requested a new Acess token.
Even now it still states "No Data". The Nord Subscription is still active and OpenVPN works without issues.
I know that its a beta but I hope that there is a solution for this issue.
You always could before. Here is a howto for it, you just need a Linux like Ubuntu in a VM like Virtualbox. It takes like 20 minutes to complete with installation and extracting the WG config file.
I am using Nordvpn WG since years also on previous 4.6 fw.
Not sure how Glinet does this with the new FW, it would be new to me, that Nordvpn supports this officially, or if they use a cloud based solution for this to extract and copy the config file to you, which would be bad because Glinet then had access to your private keys.
Or they use the same extraction script
I've used the directions found here and have been doing this for about 6 months. It will create the configuration file for you and all you need to do is import it into your router.
We're working on it now, you can try downloading and upgrading to the latest firmware version.
Will that work? And where can I find the latest?
https://dl.gl-inet.com/router/x3000/beta
This has been updated to Beta 5
Edit: Looks like it has been updated to v4.7.1 now.
something is not working well, nord vpn shows my ip in Romania!
The problem is from NordVPN, or is it a problem with the new firmware version?
Right, mine keeps defaulting to Romania as well. Looks like it may be a Nord issue as it does this with the NordApp on my phone.
it works again
No it does not. I connected to Spain and I recived a german IP.
Please try to use the latest version of 4.7, thanks.
