is no problem. The MWAN 3 doesn’t check vpn, but only physical Internet connections, e.g. cable, repeater, 3G/4G or tethering. It has to ensure one physical Internet connection is working so that your vpn can go through. Of course MWAN3 can control vpn interfaces. But that make sense if you have multiple VPN connections and want to have load balancing. We don’t want to make this so complicated.
Features:
5 will be investigated and added
is already there. The 3 LEDs will flash one by one when upgrading firmware.
There is a bar for wifi tx power in wifi page, just drag it and it works immediately.
Overall, thanks for your suggestions and it is very valuable.
The line of sight range is still ~25 meters when set to 0 dBi =)
If I use WiFi in a hotel room or motor vehicle sometimes I want lower Tx power…
Can the router WiFi chip driver permit a reduced power setting of < 1 mW / 0 dBm ?
I saw the colorful firmware update badge notification on the routers web interface today. This looks good. But please show change log for all firmware updates in future so the user knows which bugs are fixed.
