MT7621 stage1 code Dec 16 2019 17:45:55 (ASIC)
CPU=500000000 HZ BUS=166666666 HZ
Change MPLL source from XTAL to CR...
do MEMPLL setting..
MEMPLL Config : 0x11000000
3PLL mode + External loopback
=== XTAL-40Mhz === DDR-1200Mhz ===
PLL3 FB_DL: 0x2, 1/0 = 744/280 09000000
PLL2 FB_DL: 0x7, 1/0 = 572/452 1D000000
PLL4 FB_DL: 0x16, 1/0 = 552/472 59000000
DDR patch working
do DDR setting..[01F40400]
Apply DDR3 Setting...(use default AC)
0 8 16 24 32 40 48 56 64 72 80 88 96 104 112 120
0000:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0001:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0002:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0003:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0004:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0005:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0006:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0007:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0008:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0009:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
000A:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
000B:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
000C:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
000D:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1
000E:| 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1
000F:| 0 0 0 0 1 1 1 1 1 1 1 1 1 0 0 0
0010:| 1 1 1 1 1 1 1 1 0 0 0 0 0 0 0 0
0011:| 1 1 1 1 0 0 0 0 0 0 0 0 0 0 0 0
0012:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0013:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0014:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0015:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0016:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0017:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0018:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0019:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
001A:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
001B:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
001C:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
001D:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
001E:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
001F:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
DRAMC_DQSCTL1[0e0]=13000000
DRAMC_DQSGCTL[124]=80000033
rank 0 coarse = 15
rank 0 fine = 64
B:| 0 0 0 0 0 0 0 0 0 0 1 1 1 0 0 0
opt_dle value:11
DRAMC_DDR2CTL[07c]=C287223D
DRAMC_PADCTL4[0e4]=000022B3
DRAMC_DQIDLY1[210]=0C090909
DRAMC_DQIDLY2[214]=0709090C
DRAMC_DQIDLY3[218]=0A0A0A07
DRAMC_DQIDLY4[21c]=0A0A0908
DRAMC_R0DELDLY[018]=00001C1B
RX DQS perbit delay software calibration
1.0-15 bit dq delay value
bit| 0 1 2 3 4 5 6 7 8 9
0 | 9 7 7 11 11 9 9 7 6 7
10 | 9 9 8 7 9 9
2.dqs window
x=pass dqs delay value (min~max)center
y=0-7bit DQ of every group
input delay:DQS0 =27 DQS1 = 28
bit DQS0 bit DQS1
0 (1~53)27 8 (1~53)27
1 (1~49)25 9 (1~49)25
2 (1~50)25 10 (1~54)27
3 (1~52)26 11 (1~53)27
4 (1~52)26 12 (1~56)28
5 (2~52)27 13 (1~52)26
6 (1~53)27 14 (1~54)27
7 (1~53)27 15 (1~53)27
3.dq delay value last
0 | 9 9 9 12 12 9 9 7 7 10
10 | 10 10 8 9 10 10
TX perbyte calibration
DQS loop = 15, cmp_err_1 = ffff5a11
DQS loop = 14, cmp_err_1 = ffff0000
dqs_perbyte_dly.last_dqsdly_pass[0]=14, finish count=1
dqs_perbyte_dly.last_dqsdly_pass[1]=14, finish count=2
DQ loop=15, cmp_err_1 = ffff00ef
dqs_perbyte_dly.last_dqdly_pass[1]=15, finish count=1
DQ loop=14, cmp_err_1 = ffff00a6
DQ loop=13, cmp_err_1 = ffff00a6
DQ loop=12, cmp_err_1 = ffff0002
DQ loop=11, cmp_err_1 = ffff0000
dqs_perbyte_dly.last_dqdly_pass[0]=11, finish count=2
byte:0, (DQS,DQ)=(9,8)
byte:1, (DQS,DQ)=(8,8)
DRAMC_DQODLY1[200]=88888888
DRAMC_DQODLY2[204]=88888888
20,data:89
[EMI] DRAMC calibration passed
MT7621 stage1 code done
U-Boot SPL 2025.04-rc3 (Aug 10 2026 - 16:17:27 +0800)
Trying to boot from NOR
U-Boot 2025.04-rc3 (Aug 10 2026 - 16:17:27 +0800)
CPU: MediaTek MT7621A ver 1, eco 3
Boot: DDR3, SPI-NOR 3-Byte Addr
Clock: CPU: 880MHz, DDR: 1200MT/s, Bus: 220MHz, XTAL: 40MHz
Model: MediaTek MT7621 RFB (SPI-NOR)
DRAM: 128 MiB
Core: 45 devices, 22 uclasses, devicetree: separate
MMC: mmc@1e130000: 0
Loading Environment from MTD... spi_nand spi_nand@0: CASN page check failed
SF: Detected en25qe16a with page size 256 Bytes, erase size 4 KiB, total 2 MiB
*** Warning - bad CRC, using default environment
Net: MediaTek MT7530
Warning: eth@1e100000 (eth0) using random MAC address - fe:5b:38:26:b2:9d
eth0: eth@1e100000
Enter "gl" to stop autoboot in 2 seconds
Uncompressing Kernel Image to 80001000
[ 0.000000] Linux version 6.6.119 (user@user-b860m) (mipsel-openwrt-linux-musl-gcc.bin (OpenWrt GCC 13.3.0 r29087-d9c5716d1d) 13.3.0, GNU ld (GNU Binutils) 2.42) #0 SMP Fri Oct 16 13:09:05 2026
[ 0.000000] SoC Type: MediaTek MT7621 ver:1 eco:3
[ 0.000000] printk: bootconsole [early0] enabled
[ 0.000000] CPU0 revision is: 0001992f (MIPS 1004Kc)
[ 0.000000] MIPS: machine is GL.iNet GL-MG1300
[ 0.000000] Initrd not found or empty - disabling initrd
[ 0.000000] VPE topology {2,2} total 4
[ 0.000000] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
[ 0.000000] MIPS secondary cache 256kB, 8-way, linesize 32 bytes.
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000000000000-0x0000000007ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x0000000007ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000007ffffff]
[ 0.000000] percpu: Embedded 12 pages/cpu s18976 r8192 d21984 u49152
[ 0.000000] Kernel command line: console=ttyS0,115200 rootfstype=squashfs,jffs2
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.000000] Writing ErrCtl register=0004d260
[ 0.000000] Readback ErrCtl register=0004d260
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 32480
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 117488K/131072K available (8176K kernel code, 650K rwdata, 1732K rodata, 1268K init, 220K bss, 13584K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 256
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] clocksource: GIC: mask: 0xffffffffffffffff max_cycles: 0xcaf478abb4, max_idle_ns: 440795247997 ns
[ 0.000004] sched_clock: 64 bits at 880MHz, resolution 1ns, wraps every 4398046511103ns
[ 0.008049] Calibrating delay loop... 586.13 BogoMIPS (lpj=2930688)
[ 0.066206] pid_max: default: 32768 minimum: 301
[ 0.079511] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.086745] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.102986] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[ 0.112739] rcu: Hierarchical SRCU implementation.
[ 0.117437] rcu: Max phase no-delay instances is 1000.
[ 0.123406] smp: Bringing up secondary CPUs ...
[ 0.128669] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
[ 0.128695] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
[ 0.128710] MIPS secondary cache 256kB, 8-way, linesize 32 bytes.
[ 0.128757] CPU1 revision is: 0001992f (MIPS 1004Kc)
[ 0.182837] Synchronize counters for CPU 1: done.
[ 0.214758] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
[ 0.214782] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
[ 0.214794] MIPS secondary cache 256kB, 8-way, linesize 32 bytes.
[ 0.214824] CPU2 revision is: 0001992f (MIPS 1004Kc)
[ 0.273739] Synchronize counters for CPU 2: done.
[ 0.304439] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
[ 0.304462] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
[ 0.304474] MIPS secondary cache 256kB, 8-way, linesize 32 bytes.
[ 0.304508] CPU3 revision is: 0001992f (MIPS 1004Kc)
[ 0.358942] Synchronize counters for CPU 3: done.
[ 0.388807] smp: Brought up 1 node, 4 CPUs
[ 0.399876] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.409690] futex hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.420523] pinctrl core: initialized pinctrl subsystem
[ 0.429020] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.437790] /pinctrl: Fixed dependency cycle(s) with /pinctrl/pinctrl0
[ 0.461942] clocksource: Switched to clocksource GIC
[ 0.477157] NET: Registered PF_INET protocol family
[ 0.482323] IP idents hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.490397] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 0.498720] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.506392] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.514048] TCP bind hash table entries: 1024 (order: 2, 16384 bytes, linear)
[ 0.521147] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.528439] MPTCP token hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.535966] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.542461] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.550328] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.555996] PCI: CLS 0 bytes, default 32
[ 0.563668] workingset: timestamp_bits=14 max_order=15 bucket_order=1
[ 0.572387] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.578134] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.593803] mt7621_gpio 1e000600.gpio: registering 32 gpios
[ 0.599711] mt7621_gpio 1e000600.gpio: registering 32 gpios
[ 0.605741] mt7621_gpio 1e000600.gpio: registering 32 gpios
[ 0.612131] mt7621-pci 1e140000.pcie: host bridge /pcie@1e140000 ranges:
[ 0.618804] mt7621-pci 1e140000.pcie: No bus range found for /pcie@1e140000, using [bus 00-ff]
[ 0.627570] mt7621-pci 1e140000.pcie: MEM 0x0060000000..0x006fffffff -> 0x0060000000
[ 0.635673] mt7621-pci 1e140000.pcie: IO 0x001e160000..0x001e16ffff -> 0x0000000000
[ 1.001948] mt7621-pci 1e140000.pcie: pcie1 no card, disable it (RST & CLK)
[ 1.008846] mt7621-pci 1e140000.pcie: pcie2 no card, disable it (RST & CLK)
[ 1.015806] mt7621-pci 1e140000.pcie: PCIE0 enabled
[ 1.020782] PCI coherence region base: 0x60000000, mask/settings: 0xf0000002
[ 1.027930] mt7621-pci 1e140000.pcie: PCI host bridge to bus 0000:00
[ 1.034257] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.039662] pci_bus 0000:00: root bus resource [mem 0x60000000-0x6fffffff]
[ 1.046513] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 1.052701] pci 0000:00:00.0: [0e8d:0801] type 01 class 0x060400
[ 1.058625] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x7fffffff]
[ 1.064888] pci 0000:00:00.0: reg 0x14: [mem 0x60200000-0x6020ffff]
[ 1.071122] pci 0000:00:00.0: supports D1
[ 1.075064] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 1.083294] pci 0000:01:00.0: [14c3:7615] type 00 class 0x000280
[ 1.089282] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x000fffff 64bit]
[ 1.096199] pci 0000:01:00.0: 2.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x1 link at 0000:00:00.0 (capable of 4.000 Gb/s with 5.0 GT/s PCIe x1 link)
[ 1.111315] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 1.116534] pci 0000:00:00.0: bridge window [io 0x0000-0x0fff]
[ 1.122579] pci 0000:00:00.0: bridge window [mem 0x60000000-0x600fffff]
[ 1.129278] pci 0000:00:00.0: bridge window [mem 0x60100000-0x601fffff pref]
[ 1.136482] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 1.143080] pci 0000:00:00.0: BAR 0: no space for [mem size 0x80000000]
[ 1.149594] pci 0000:00:00.0: BAR 0: failed to assign [mem size 0x80000000]
[ 1.156544] pci 0000:00:00.0: BAR 8: assigned [mem 0x60000000-0x600fffff]
[ 1.163277] pci 0000:00:00.0: BAR 9: assigned [mem 0x60100000-0x601fffff pref]
[ 1.170418] pci 0000:00:00.0: BAR 1: assigned [mem 0x60200000-0x6020ffff]
[ 1.177221] pci 0000:00:00.0: BAR 7: assigned [io 0x0000-0x0fff]
[ 1.183271] pci 0000:01:00.0: BAR 0: assigned [mem 0x60000000-0x600fffff 64bit]
[ 1.190494] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.195438] pci 0000:00:00.0: bridge window [io 0x0000-0x0fff]
[ 1.201456] pci 0000:00:00.0: bridge window [mem 0x60000000-0x600fffff]
[ 1.208224] pci 0000:00:00.0: bridge window [mem 0x60100000-0x601fffff pref]
[ 1.217168] Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
[ 1.226595] printk: console [ttyS0] disabled
[ 1.231484] 1e000c00.uartlite: ttyS0 at MMIO 0x1e000c00 (irq = 18, base_baud = 3125000) is a 16550A
[ 1.240602] printk: console [ttyS0] enabled
[ 1.248917] printk: bootconsole [early0] disabled
[ 1.263723] spi-mt7621 1e000b00.spi: sys_freq: 220000000
[ 1.270428] spi-nor spi0.0: en25qe16a (2048 Kbytes)
[ 1.275478] 5 fixed-partitions partitions found on MTD device spi0.0
[ 1.281822] Creating 5 MTD partitions on "spi0.0":
[ 1.286624] 0x000000000000-0x000000080000 : "u-boot"
[ 1.293399] 0x000000080000-0x000000090000 : "u-boot-env"
[ 1.299888] 0x000000090000-0x0000000a0000 : "factory"
[ 1.306288] OF: Bad cell count for /palmbus@1e000000/spi@b00/flash@0/partitions
[ 1.314002] 0x0000000a0000-0x0000000e0000 : "log"
[ 1.319823] 0x0000000e0000-0x000000100000 : "CFG"
[ 1.465353] mt7530-mdio mdio-bus:1f: MT7530 adapts as multi-chip module
[ 1.482282] mtk_soc_eth 1e100000.ethernet eth0: mediatek frame engine at 0xbe100000, irq 19
[ 1.493873] mtk_soc_eth 1e100000.ethernet eth1: mediatek frame engine at 0xbe100000, irq 19
[ 1.503832] i2c_dev: i2c /dev entries driver
[ 1.512304] NET: Registered PF_INET6 protocol family
[ 1.520817] Segment Routing with IPv6
[ 1.524623] In-situ OAM (IOAM) with IPv6
[ 1.528657] NET: Registered PF_PACKET protocol family
[ 1.534076] 8021q: 802.1Q VLAN Support v1.8
[ 1.568632] gpio-export gpio-export: 1 gpio(s) exported
[ 1.574414] mt7530-mdio mdio-bus:1f: MT7530 adapts as multi-chip module
[ 1.607873] mt7530-mdio mdio-bus:1f: configuring for fixed/rgmii link mode
[ 1.616750] mt7530-mdio mdio-bus:1f lan (uninitialized): PHY [mt7530-0:02] driver [MediaTek MT7530 PHY] (irq=24)
[ 1.629348] mt7530-mdio mdio-bus:1f: Link is Up - 1Gbps/Full - flow control rx/tx
[ 1.633150] mtk_soc_eth 1e100000.ethernet eth0: entered promiscuous mode
[ 1.643727] DSA: tree 0 setup
[ 1.647680] clk: Disabling unused clocks
[ 1.652342] MTD: Couldn't look up '': -22
[ 1.656462] /dev/root: Can't open blockdev
[ 1.660564] VFS: Cannot open root device "" or unknown-block(0,0): error -6
[ 1.667511] Please append a correct "root=" boot option; here are the available partitions:
[ 1.675860] 1f00 512 mtdblock0
[ 1.675875] (driver?)
[ 1.682395] 1f01 64 mtdblock1
[ 1.682406] (driver?)
[ 1.688907] 1f02 64 mtdblock2
[ 1.688916] (driver?)
[ 1.695434] 1f03 256 mtdblock3
[ 1.695446] (driver?)
[ 1.701962] 1f04 128 mtdblock4
[ 1.701974] (driver?)
[ 1.708475] List of all bdev filesystems:
[ 1.712475] squashfs
[ 1.712484]
[ 1.716218] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[ 1.724464] Rebooting in 1 seconds..
=> printenv
baudrate=115200
bootdelay=2
ethaddr=fe:5b:38:26:b2:9d
fdtcontroladdr=87cfd850
ipaddr=192.168.1.1
lf=mtkupgrade fw openwrt-gl-mg1300.bin
loadaddr=0x83000000
lu=mtkupgrade fip uboot-gl-mg1300.bin
mtdids=nor0=nor0,spi-nand0=spi-nand0
mtdparts=nor0:512k(fip),64k(u-boot-env),64k(factory),256k(log),128k(CFG);spi-nand0:-(ubi)
netmask=255.255.255.0
serverip=192.168.1.2
stderr=uart1@1e000c00
stdin=uart1@1e000c00
stdout=uart1@1e000c00
Environment size: 430/4092 bytes
=> help
? - alias for 'help'
base - print or set address offset
bdinfo - print Board Info structure
blkcache - block cache diagnostics and control
boot - boot default, i.e., run 'bootcmd'
bootd - boot default, i.e., run 'bootcmd'
bootflow - Boot flows
bootm - boot application image from memory
bootmenu - ANSI terminal bootmenu
bootp - boot image via network using BOOTP/TFTP protocol
button - manage buttons
chpart - change active partition of a MTD device
cmp - memory compare
coninfo - print console devices and information
cp - memory copy
cyclic - Cyclic
dhcp - boot image via network using DHCP/TFTP protocol
echo - echo args to console
editenv - edit environment variable
env - environment handling commands
fdt - flattened device tree utility commands
glbtn - GL-iNet button check
go - start application at address 'addr'
gpio - query and control gpio pins
help - print command description/usage
httpd - Start failsafe HTTP server
iminfo - print header information for application image
itest - return true/false on integer compare
led - manage LEDs
loadb - load binary file over serial line (kermit mode)
loadx - load binary file over serial line (xmodem mode)
loady - load binary file over serial line (ymodem mode)
loop - infinite loop on address range
md - memory display
mm - memory modify (auto-incrementing address)
mmc - MMC sub system
mmcinfo - display MMC info
mtd - MTD utils
mtdparts - define flash/nand partitions
mtkautoboot- Display MediaTek bootmenu
mtkboardboot- Boot MTK firmware
mtkbootconf- Setup bootconf for FIT image
mtkload - MTK image loading utility
mtkupgrade- MTK firmware/bootloader upgrading utility
mw - memory write (fill)
nand - NAND utility
net - NET sub-system
nm - memory modify (constant address)
panic - Panic with optional message
part - disk partition related commands
ping - send ICMP ECHO_REQUEST to network host
printenv - print environment variables
random - fill memory with random pattern
reset - Perform RESET of the CPU
run - run commands in an environment variable
saveenv - save environment variables to persistent storage
setenv - set environment variables
setexpr - set environment variable as the result of eval expression
sf - SPI flash sub-system
sleep - delay execution for some time
source - run script from memory
sspi - SPI utility command
tftpboot - load file via network using TFTP protocol
ubi - ubi commands
ubifsload - load file from an UBIFS filesystem
ubifsls - list files in a directory
ubifsmount- mount UBIFS volume
ubifsumount- unmount UBIFS volume
version - print monitor, compiler and linker version
Ok use lan connect to 192.168.1.1
httpd
=> httpd
Web failsafe UI started
URL: http://192.168.1.1/
Press Ctrl+C to exit
mt7530 Waiting for port auto negotiation to complete.. TIMEOUT ! (ignored)
upload via web interface
immortalwrt-ramips-mt7621-glinet_gl-mg1300-squashfs-sysupgrade.bin
root@GL-MG1300:~# cat /proc/cmdline
git clone -b gl-mg1300 https://github.com/i-can-penguin/openwrt.git
cd openwrt
cp -r boards/ekh-mt7621 boards/gl-mg1300
nano boards/gl-mg1300/target_diffconfig
CONFIG_TARGET_ramips=y
CONFIG_TARGET_ramips_mt7621=y
CONFIG_TARGET_ramips_mt7621_DEVICE_glinet_gl-mg1300=y
CONFIG_TARGET_SQUASHFS_BLOCK_SIZE=1024
CONFIG_TARGET_ROOTFS_SQUASHFS=y
CONFIG_TARGET_ROOTFS_INITRAMFS=y
CONFIG_TARGET_ROOTFS_UBIFS=y
CONFIG_TARGET_PREINIT_IP="10.42.0.1"
CONFIG_TARGET_PREINIT_BROADCAST="10.42.0.255"
CONFIG_TARGET_DEFAULT_LAN_IP_FROM_PREINIT=y
CONFIG_PACKAGE_morse-board-config-hotplug-model=y
CONFIG_PACKAGE_luci-app-ekhwizards=y
CONFIG_PACKAGE_kmod-usb-storage=y
CONFIG_PACKAGE_block-mount=y
CONFIG_PACKAGE_kmod-morse=y
CONFIG_PACKAGE_netifd-morse=y
CONFIG_PACKAGE_morse-fw-8108=y
CONFIG_PACKAGE_morse-fw-8108-tlm=y
CONFIG_PACKAGE_morse-fw-8108-flm=y
CONFIG_PACKAGE_kmod-bluetooth=y
CONFIG_PACKAGE_bluez-libs=y
did try add kmod-spi-dev with make menuconfig
also tried adding these to config-6-6 but does not help...
CONFIG_MTD_SPI_NAND=y
CONFIG_MTD_UBI=y
./scripts/morse_setup.sh -i -E -b gl-mg1300
make -j3
but still have issue with using Morse Micro OpenWRT SDK to have spi nand support
Received the other English branded EU version this morning
